Boosted?
11 Feb 2023 11:25 - 11 Feb 2023 11:25 #247557 by Motleycrew
Replied by Motleycrew on topic Boosted?
No internal work done. I was actually dissuaded by a UK Suzuki company that sells forging parts. There is an issue with high boost pressure is that the cylinder liners rotate every so slightly and cause the head gasket to go. His personal car has had a brace put on by a specialist. So unless you get that done it’s not worth putting rods, pistons etc as that will be the limiting factor. Become a lot of money. If I had the funds I would put a Honda K series engine in and then it really will be a monster. A few people on this forum seem to think that a turbo equates uncontrollable power which is just naive. A fiat 500 abarth 595 is about 160-80BHP and you don’t see them in ditches. I will bring mine to a meet up.
Last edit: 11 Feb 2023 11:25 by Motleycrew.
11 Feb 2023 11:27 #247558 by Motleycrew
The fact is hasn’t got a limited slip diff means one rear wheel just spins so it doesn’t kick you off the road. Just one wheel spins on the spot. Predictable and actually boring as you can’t get the power down.
11 Feb 2023 21:44 - 11 Feb 2023 21:46 #247570 by lightning
Replied by lightning on topic Boosted?
" A few people on this forum seem to think that a turbo equates uncontrollable power which is just naive. A fiat 500 abarth 595 is about 160-80BHP and you don’t see them in ditches. I will bring mine to a meet up"
The 595 Abarth is designed to handle the power, it's got a much lower C of G, also it's FWD and not a ladder frame chassis with RWD.
Of course you can improve the Jimny suspension by lowering etc but on a wet road our Gen 4 is marginal with the standard 100bhp hence my concerns about dumping 150bhp+ through the rear wheels.
Last edit: 11 Feb 2023 21:46 by lightning.
12 Feb 2023 05:23 #247571 by Lambert
Replied by Lambert on topic Boosted?
There's also the issue of stopping the car . With my last Jimny I had improved the quality of the braking system as far as I could with the standard solid discs and with the improvements in handling I also had it was very marginal at best as I could induce fade within 3 or 4 laps of say teeside drift circuit. Obviously I was conscious of the shortcomings and was aware of the vented disc conversion but that was with only a mildly warmed 1.3, doubling the power is going to cause even upgraded brakes to have their limits found very easily.
12 Feb 2023 10:50 #247572 by Motleycrew
This is what I was inspired with the Jimny
12 Feb 2023 11:08 #247573 by 300bhpton
Replied by 300bhpton on topic Boosted?
I wouldn’t say the stock 101bhp is marginal in the Jimny. I’ve driven mine pretty hard and the only time it’ll try and spin the wheels on the road is pulling away on a slight incline with a tight turn and steering lock on. Or in the snow. But otherwise it is fine.
I’m sure more power would make them more feisty. But you are never going to have 300ft lb of torque at 1500rpm. It will always be a fairly revvy little engine.
Time to create page: 0.157 seconds
