Boosted?
  • JKemo35
09 Feb 2023 11:47 #247464 by JKemo35
Boosted? was created by JKemo35
So I plan on doing an engine swap on my jimny and I'm dead set on boosting it (probably supercharging it because I'm different) and was looking at specs between 1.6's on different vehicles noticing the different compression ratios, my wondering is, do I get a 11.1 comp ratio 125hp engine out a swift running less boost or a 9.7 comp ratio 102hp engine out of the liana and run more boost, basically I'm after as much power as possible while keeping it reliable, forged rods may be in the budget as I've heard the standards don't handle much boost, so basically what engine would the best option for max power?, many thanks
09 Feb 2023 12:08 #247466 by DrRobin
Replied by DrRobin on topic Boosted?
You might want to look at this thread
www.bigjimny.com/index.php/forum/7-jimny...supercharger-to-gen4
Or Rotrex website
www.rotrex.com/centrifugal-superchargers...y-supercharger-kits/
I am not sure if there is anyone on here has actually done what you want to do, so you might be breaking new ground as well as breaking engines and transmission components on a regular basis.
I doubt that the standard transfer box will take such a big up lift in power and then possibly the diffs will give out quickly, not sure about the clutch either, lots and lots to go wrong.
Why do you need such a big increase in power?
  • JKemo35
09 Feb 2023 12:33 #247467 by JKemo35
Replied by JKemo35 on topic Boosted?
I've seen many posts of people turboing a 1.6, not seen anything said about transfer boxes giving way nor diffs, people have mentioned about the half shafts going but what I read they were also running quite large tyres. Clutch will obviously need doing but that's a given. I'm not looking for drag strip numbers but 170 maybe 180 break reliably would be perfect. It all boils down to me absolutely loving the car but it's just too slow for my liking/driving.
09 Feb 2023 13:12 #247472 by jackonlyjack
Replied by jackonlyjack on topic Boosted?
Member Keithy is the turbo man
jimny4k.com
think he ran standard M13A @25psi (to see what happened)
it lasted around 3 months used daily
09 Feb 2023 17:03 - 09 Feb 2023 17:04 #247477 by yakuza
Replied by yakuza on topic Boosted?
After swapping my 80hp m13 to a 105hp m16 I have changed the gearbox, the rear driveshaft, and the rear diff. But I drive like stupid.
Last edit: 09 Feb 2023 17:04 by yakuza.
09 Feb 2023 18:41 #247485 by Lambert
Replied by Lambert on topic Boosted?
As someone who used to track day a manual Jimny I would suggest you are looking in the wrong place. Lower the ride height, firm up the damping and get some sticky road tyres and if you are anything like talented behind the wheel you will be hunting sports cars on back roads because they are easy pickings.
Time to create page: 0.110 seconds
