Jimny commercial
- dafydd
19 Jul 2021 22:00 #236821
by dafydd
Replied by dafydd on topic Jimny commercial - driving position
Re - seating position
The YouTube showing the guy removing the mesh and bulkhead was excellent - thanks for the heads up. I think I will remove them and see if I can reverse the mesh using spacers as suggested by Martin
20 Jul 2021 03:42 #236822
Sent from my moto g(
power using Tapatalk
Replied by mlines on topic Re:Jimny commercial - driving position
I went out for a closer look. As someone said, even if the mesh is removed or repositioned the steel panel below fouls the seat back. The only quick and easy way would be to remove the lot. Spacing the mesh away looks to be problematic as the existing captive nuts would get in the waydafydd wrote: Re - seating position
The following user(s) said Thank You: Coco BT
- Roger Fairclough
- Thank you received: 225
20 Jul 2021 07:58 #236824
by Roger Fairclough
Replied by Roger Fairclough on topic Re:Jimny commercial - driving position
Startin of Redditch charge list.
Roger
Roger
- Axholme Lion
20 Jul 2021 12:41 #236831
by Axholme Lion
Replied by Axholme Lion on topic Re:Re:Re:Jimny commercial
Hi Lydia, Baden Powell at Scunthorpe are charging the proper RRP. That's where i have ordered a commercial from. They do take a deposit to stop time wasters but it's returnable if you change your mind. I have already turned down a white one, it just depends on the colours they are allocated and what people on the list want.
20 Jul 2021 21:39 #236840
by Trakito1
Replied by Trakito1 on topic Re:Jimny commercial - driving position
After removing the bulkhead and the mesh weeks ago, i tried to refit both with the mesh angled backwards but unable to as it attaches to the bulkhead to keep it in place. Both parts are dependent on each other to keep in place. I refitted both in the original configuration and just about found the most comfortable seat position. Not taken it for a long drive though so only time will tell.
20 Jul 2021 22:02 #236841
by Coco BT
Replied by Coco BT on topic Re:Jimny commercial
Just started following your SZ4 commercial journey/ mods
DRL will be ordered next week, then the roof trim.
Is there any option to upgrade the headlight (bulbs?) as yet?
Time to create page: 0.342 seconds
