Jimny commercial
17 Jul 2021 22:53 #236763 by lightning
Do you mean that the seat needs to be so far back that the back rest has to be straight?
How tall are you?
  • nogbad
17 Jul 2021 22:55 #236764 by nogbad
Replied by nogbad on topic Jimny commercial - driving position
You can remove the mess and bulkhead it's just a few bolts and problem solved, unless because it's a commercial there is some legal requirement to have it in I'm sure someone on here will have the correct information for you.
18 Jul 2021 04:42 #236765 by Lambert
The other alternative than removing the mesh looks to be turning it round so the protruding bit faces the back. Apparently it is symmetrical so should be possible.
18 Jul 2021 07:56 #236767 by Roger Fairclough
Is it so that Suzuki can claim a certain capacity in the rear compartment?
Roger
18 Jul 2021 08:19 #236768 by mlines
Replied by mlines on topic Re:Re:Re:Re:Jimny commercial
Roger Fairclough wrote: Is it so that Suzuki can claim a certain capacity in the rear compartment?
Roger
Sort of. The seats are moved 10mm so that the screen can fit in. The screen actually shortens the overall rear floor space so the required volume is achieved by dropping the floor height.
The headrest hits the screen so limiting the seat angle. It does looks like the screen can be fitted slightly back, either by reversing it or by making M6 threaded spacers ( I might try that)
Sent from my moto g(8) power using Tapatalk
18 Jul 2021 10:59 #236774 by Roger Fairclough
10mm is not a lot so maybe some work with the fixing brackets may be the answer to the lower screen and a change in the top screen angle by either riv-nuts or modification to the top mounting bracket may work.
Maybe another how to Martin?
Roger
Time to create page: 0.281 seconds
