Re:Gen4 Workshop Manual
24 Feb 2021 08:55 #233194 by mlines
Replied by mlines on topic Re:Gen4 Workshop Manual
Have you checked the permissions and sharing are the same as the file iisstart.htm?
24 Feb 2021 09:05 #233195 by Roger Fairclough
Yes all identical....inherited from permission on wwwroot file.
Viv
24 Feb 2021 09:38 #233197 by mlines
can you make a copy of top.html  and call it "index.htm" an see what happens when you simply type in "localhost"
24 Feb 2021 09:47 #233198 by Roger Fairclough
It comes up with Error 401.3 unauthorised.
24 Feb 2021 11:10 #233207 by mlines
Just to check, depending on the browser etc. it can be case sensitive so make sure it matches the target file.
localhost/Top/TopPage.html
Apart from that I can only think it is something to do with having multiple users on the PC including an admin user. If the "index.htm" file you created has the same parameters as the iisstart.htm file, I cannot see why it doesnt work.
The logging files for IIS are in C:\windows\\system32\Logfiles\    - I have a subdirectory called HTTPERR
24 Feb 2021 12:06 #233208 by Roger Fairclough
Just tried again with the same result. Not authorised.
I have the same path for the logging file.
Having looked at everything to do with permissions this morning I too am coming to the conclusions it is something to do with multiple users. I even removed my basic user account from the permissions but it didn't make any difference.
The last alternative I can see is to remove both basic accounts and see if it will run from the administrator account.
Thanks
24 Feb 2021 12:46 #233209 by Roger Fairclough
So the good news is I can now type localhost/Top.html and get into the system.
The bad news is is will still NOT display any pictures that require Flash.
For example -Suspension then Front Suspension.....
Front Wheel Alignment with not show anything except the Flash logo
BUT
Front Suspension Components will show the diagram.
This is as per the CD rom BUT has the added benefit of being easier to use this way than keep getting out the CD.
Thanks for all of your time Martin.
24 Feb 2021 13:05 #233210 by mlines
You are certainly having strange issues that myself and others have not seen, it just simply works for us.
Do you know if its Windows 10 Pro or Windows 10 Home?
24 Feb 2021 13:22 #233211 by mlines
You have a PM
24 Feb 2021 13:41 #233217 by Roger Fairclough
Windows 10 Home
Viv
24 Feb 2021 15:07 #233222 by Roger Fairclough
It Works
I have consistently used Internet Explorer but just decided to see what would happen if I used Google Chrome Browser Instead.
I have only selected a couple of items but they now have diagrams and pictures rather than the F Adobe logo.
Time for a glass of something.
Viv
24 Feb 2021 15:39 #233225 by Soeley
Replied by Soeley on topic Re:Gen4 Workshop Manual
Mine works in both Edge and Chrome, not tried Internet Explorer yet. Might do later.
Glad it's working for you, better than getting your money back.
