Re:Gen4 Workshop Manual
23 Feb 2021 15:07 #233148 by mlines
Replied by mlines on topic Gen4 Workshop Manual
Looking around the suggestion is that this can happen if you install onto a Windows 10 system that has some broken files in it.
I guess it could also be the firewall, although you say it stops all web access which is more consistent with the first item apparently.
To check the file system, open a Command Prompt with Admin privileges and type in " SFC /scannow "
23 Feb 2021 15:14 #233150 by Roger Fairclough
Thanks Martin. I will try what you suggest.
As a point of interest. Is there a port number that should be open on the firewall so that I can check it on McAfee.
Viv
23 Feb 2021 15:24 #233151 by mlines
The standard port is port 80 (should be open for both TCP and UDP)
23 Feb 2021 15:52 #233155 by Roger Fairclough
Ran SFC/scannow and it said corrupt files found and successfully repaired. So ready to have another go.
I have set up ready to copy files into wwwroot folder but before I do so, can I just check wwwroot properties....and sharing.
Properties are showing as read only. Is this ok?
Sharing....As computer split between admin and 2 users do I need to add Roger as a user?
I will also double check that McAfee has Port 80 open as advised.
Sorry about this Martin, its been a long time since I did any computer stuff.
Viv
23 Feb 2021 16:05 #233157 by Gadget
Replied by Gadget on topic Re:Gen4 Workshop Manual
mlines wrote: See here how to fix it....
So. Many. Desktop. Icons. Aaaaaargh! OCD triggered!
23 Feb 2021 16:37 #233158 by mlines
No problem
read only should be fine.
Sharing - it should have set them to IIS Users automatically.
If you have two users PLUS admin, make sure all the installation and copying etc is done from the Admin account.
23 Feb 2021 16:38 #233159 by mlines
Replied by mlines on topic Re:Gen4 Workshop Manual
Also my pet hate - is a single login multi-user home PC. I try and clean it up regularly
23 Feb 2021 17:24 #233160 by Roger Fairclough
Have made sure all okay but McAfee only show Web server Port 80 as TCP/IP - no mention of a UDP port.
Yes, all installation etc done from administrator account.
Internet Explore still saying INET_E_RESOURCE_NOT_FOUND
Its driven me nuts so I will try and walk away for now.
Viv
23 Feb 2021 17:57 #233164 by Roger Fairclough
Just as I was walking away....I tried one last time and got a different message when typing localhost/ in browser
HTTP Error 401.3 - Unauthorised
Something to do with not having permission because of the ACL (access control list) configuration or encryption settings for the resource of the web server.
Back to the drawing board for something different to try perhaps later.
Viv
23 Feb 2021 19:04 - 23 Feb 2021 19:07 #233167 by mlines
This is positive news as 401.3 is a message from the IIS software, so that is installed and running. This now a permission problem,
Did you type in just "localhost" (which will not work) or localhost/iisstart.htm  which should
stackoverflow.com/questions/5900616/http...nauthorized/12924617
Last edit: 23 Feb 2021 19:07 by mlines.
23 Feb 2021 20:42 #233172 by Roger Fairclough
At this precise moment I am pleased to say that
HTTP://localhost/isstart.htm will open up the Windows IIS Welcome Page.
So tomorrow morning, I will recopy the CD files into the wwwroot folder and
hopefully........watch this space.
Thanks Viv
The following user(s) said Thank You: mlines
24 Feb 2021 08:50 #233193 by Roger Fairclough
Ok..almost there....hopefully
The files have been transferred and are all now in the wwwroot file
I have tried both http://locahost/top.html and http://localhost/top/toppage.html
Both generate the HTTP Error 404.0 not authorised.
I have checked permissions and sharing exactly as for wwwroot.
Any suggestions would be appreciated.
Thankyou
Time to create page: 0.216 seconds
