Re:Gen4 Workshop Manual
  • Groenewald
  • Visitor
  • Visitor
22 Feb 2021 09:33 - 22 Feb 2021 09:33 #233090 by Groenewald
Replied by Groenewald on topic Gen4 Workshop Manual
It would be ideal to convert the CD based version to run from a MySQL database with a PHP/HTML front end.
  • Searching Facilities
  • Print / Export (if required)
  • Granular add/edit permissions
  • User groups, user account control and audit trails for logins, option to activate/deactivate user accounts
  • Etc.....
This way it will run 100% on anything with an internet connection, even mobile phones.
Wonder what would happen if Suzuki were approached with this?
If red tape will be an issue, stuff that - We build our own service manual database. With all the guys on here and all the stuff they do it should not be an issue to get something populated pretty quickly.
Last edit: 22 Feb 2021 09:33 by Groenewald.
22 Feb 2021 10:33 #233092 by mlines
Replied by mlines on topic Gen4 Workshop Manual
Just update the wiki on this website to create your own manual, just dont use copyright info
22 Feb 2021 18:00 #233107 by Roger Fairclough
I have received two grovelling apologies from Suzuki GB. Basically I can have my money back and that's it.
So, unless someone who is far more computer literate than Viv or myself can come up with a practical way to con the info out of my, apparently, worthless cd, I will be be taking my money back whilst I give the parts dept . my dirtiest look.
Roger
22 Feb 2021 19:14 #233111 by mlines
Replied by mlines on topic Re:Gen4 Workshop Manual
See here how to fix it....
The following user(s) said Thank You: Gadget, Soeley
22 Feb 2021 20:59 #233114 by Soeley
Replied by Soeley on topic Gen4 Workshop Manual
Thanks for this Martin,
Just copying the file over now, being a bit slow as I'm using my old DVD rom in a caddy with USB connection only. At first I couldn't copy the files over as the wwwroot folder was Read Only. I couldn't turn off the Read Only from the Properties, I had to go into Security settings on the folder first to give permissions to Users, then switch oof Read Only.
I hope it works for me :)
22 Feb 2021 21:59 #233117 by Soeley
All working, Thanks Martin.
And no need to get the external DVD-rom out every time I want to use it now
23 Feb 2021 09:46 #233127 by Roger Fairclough
Thank you Martin. I will hang onto the disc and Viv will do the business later.
Just as a matter of interest, how many forum members bought a disc?
Roger
23 Feb 2021 09:50 #233128 by mlines
I dont know how many. I bought the early version and also subscribe to the online service. I use the dvd version for initial lookup and occasionally look at the subscription version to check for updates.
23 Feb 2021 11:54 #233134 by Roger Fairclough
Hi Martin...Its Viv (Rogers other half)
Have just tried to set this up and it all seemed to go very well.....until the last bit.
When I went to Internet Explorer and typed localhost/top.html I got the following error message
INET_E_RESOURCE_NOT_FOUND
I did check and the files were in the inetpub\wwwroot file.
Any suggestions please of what I should check.?
Also should all of the sub folders under the Internet Information Services folder be checked as I noticed that by default the FTP box remained clear.
Thank you
Viv
23 Feb 2021 12:01 #233136 by mlines
Hi Viv
What do you see if you type
http://localhost/iisstart.htm
23 Feb 2021 12:03 #233137 by mlines
Or try
http://localhost/Top/TopPage.html
23 Feb 2021 12:12 #233138 by Roger Fairclough
I tried various ways without succes and as I could not then even connect to any websites I did a system restore to take things back to first thing this morning. All working and ready to try again now.
One question. I use McAfee Livesave and wondered if this could be causing any problems with the firewall?
Viv
Time to create page: 0.217 seconds
