Pug TUD5 conversion plates
18 Sep 2020 12:51 #228314
by Busta
Replied by Busta on topic Pug TUD5 conversion plates
What is it you're hoping to achieve with the engine swap? You talk about the lack of acceleration from the 1.3, but then mention a number of diesel engines that have significantly less power. Acceleration is determined by the engine's power output, not what fuel it uses. In their standard application, fitted to tiny 900kg FWD cars, the 1.7SDI and 1.5TUD both achieve worse performance than your Jimny with its 1.3 petrol. You don't mention which Landcruiser you owned, but the Jimny 0-60 time is the same as a 4.2td Amazon and is not far behind a 3.0 D4D
Given that any engine swap is going to be expensive and involve lots of custom parts you might as well fit the best engine you can. It will cost you roughly the same to fit that 28hp Kubota engine as it will to fit a 130hp VW PD engine.
- Almai2222
18 Sep 2020 22:49 #228325
by Almai2222
Replied by Almai2222 on topic Pug TUD5 conversion plates
Lambert - I've bought a decent Jimny, owner before me was ontop of the servicing, and as an engine, it runs well, but im just not a petrol fan, more my preference than the engine
Jackonlyjack - cheers for the info, ill check them out ASAP, someone who's done one before would be a massive help to learn any mistakes or issues to expect
Busta - Totally see your point, and where the contradiction comes in. As I said to Lambert, just not a petrol fan, much more comfortable working on diesels. And the toss up between low power with the 1.7sdi or 1.5 Pug I definitely agree would be comparable to the M13A, however, i live in the sticks, and need something that (should the proverbial manure hit the fan) I can have a better change of sorting one, and id take the better mileage at a power cost. Had the pre D4D 3.0, which whilst not blistering, had decent go, just veeery thirsty for what I used it for.
Cost wise: Kubota (1305/1505) roughly £1000, then a case of refab mounts, reposition starter to fit jimny box, reposition power steering pump, but of flywheel adjustment to fit and it sits very comfortably in a jimny (as has been shown on Youtube - and for a 1.1L, goes well). Not sure how that compares to the VAG 1.9tdi swap? I'd assume there's more cost to reposition certain anxillaries etc but a cheaper engine?
19 Sep 2020 08:11 - 19 Sep 2020 08:22 #228327
by Gadget
Replied by Gadget on topic Pug TUD5 conversion plates
Am I missing something, or has that Kubota engine only got about 30hp? That's about a third of the stock 1.3. The TUD5 is also down on both power and torque over the 1.3.
I think you'd be crazy to spend 4 figures swapping in such a puny engine simply due to a preference for diesel or as preparation for a SHTF scenario that has a miniscule risk of occuring. Go diesel by all means, but at least use an engine that's equivalent or better than the petrol unit you've got at the moment.
Last edit: 19 Sep 2020 08:22 by Gadget.
19 Sep 2020 08:34 #228328
by Old Neil
Replied by Old Neil on topic Re:Pug TUD5 conversion plates
Were in rev range does the diesel produce it's power, original 1.3 is a high revving motor, wouldn't the gearing be all wrong
- Thank you received: 1875
19 Sep 2020 09:12 #228329
Replied by Lambert on topic Re:Pug TUD5 conversion plates
Very true. You wouldn't have a problem with torque. Or speed limits for that matter.
19 Sep 2020 09:38 #228330
Thinking about this more, I honestly believe that the best course of action is to just drive it as it is for a couple of months. Get used to it. I drove a 90 as a daily prior to my Dreadnaught and it did take a while to acclimatise my driving style, no more riding the turbo torque curve at 1500 rpm up hills etc. Instead it's a gear change and 3500 rpm. Not that it won't pull from 1000 rpm because it will and fully loaded with a trailer on too, admittedly Dreadnaught is not setting the world on fire towing a trailer but in fairness you shouldn't be trying to when towing anyway. As for ease of maintenance you'll struggle with reliability more with any engine conversion than sticking with something designed to be there in the first place. This is why the 1.6 swap is so popular, in all major respects they're the same engine just with more capacity so everything is in the same place and everything fits and is available easily.
I'm not saying don't do it I'm just not sure if the juice is worth the squeeze.
Time to create page: 0.617 seconds
