Re:Re:Recovery adapter.
- Thank you received: 1983
29 Aug 2020 17:00 #227507
Replied by Lambert on topic Recovery adapter.
That looks good for the departure angle, though I thought that towbars had to be type approved? But yeah mine is slightly different but the idea is the same a steel block bolted between the flanges with a big hole for a shackle.
29 Aug 2020 17:09 #227508
As for shock loading that's why I'm not the owner of a snatch strap. Kerr is the way, less violent on the recovered vehicle.
29 Aug 2020 17:33 #227510
Replied by jackonlyjack on topic Recovery adapter.
The trick is when you're first stuck (recover at this stage)
Don't keep trying to get out,you just dig in more
Needing silly amounts of force to get you out
29 Aug 2020 17:37 #227511
Experience is everything. It also helps if you have a tractor! :laugh:
- Roger Fairclough
- Thank you received: 225
29 Aug 2020 18:38 #227512
by Roger Fairclough
Replied by Roger Fairclough on topic Recovery adapter.
A KERR can be lethal if the recovery points are weak. Never use one on a tow ball as the forces involved can rip the mountings apart. The British Army only use KERR between armoured vehicles. Each rope is tagged and only used 6 times and then destroyed. They never use them on Land-rovers. I saw the rear crossmember (yes it was corroded) on a series Land-Rover ripped from the chassis rails and slammed into the back door of the Range Rover that was doing the pulling. Re-read what jackonlyjack has to say above.
Use of a KERR is taken to lightly. One guy died when the tow ball was ripped off the back of a motor and went through the back window of his motor and hit him in the back of his head.
Roger
Roger
29 Aug 2020 18:52 #227513
Or the exact opposite.
Time to create page: 0.293 seconds
