Re:Re:Recovery adapter.
- CC Baxter
Experience is something, a tractor is everthing
Chris
Roger Fairclough wrote: A KERR can be lethal if the recovery points are weak. Never use one on a tow ball as the forces involved can rip the mountings apart.
Roger
I do not believe this to be correct. A Kerr is far kinder to any mounting point as it isn’t an instant violent snatch. Anyone who has ever used a Kerr vs a regular rope will be able to reconcile this.
A number of off road clubs around here have banned them.
They are woven to be elastic. The towing car accelerates away and it's kinetic energy is stored up in the stretched rope. This builds up significant levels of energy that is released in a short burst. A two ton towing vehicle can generate up to 8 tonnes of energy.
- Thank you received: 1983
mlines wrote: Roger is correct, Kerrs can be very dangerous due to the way they store and release the energy. As said, they were designed for the army using tanks recovering tanks.
People ban them when not understanding them IMO.
The shock loading is far less with a Kerr. And it is the shock loading that causes recovery points to fail.
You can test it out easy enough. Get a rubber band and a short length of string.
Pinch the rubber band between your fingers (finger & thumb) and “snatch” it with you free hand. Chances are you will retain hold of the rubber band.
Do the same with the string and it’ll be very difficult to keep hold of it.
All the instant shock loading is not good for recovery points. A Kerr is far more gentle. And therefore less likely to cause a failure.
- Roger Fairclough
- Thank you received: 225
Nylon snatch straps look a lot like lifting straps but are woven to stretch. I have one in the Jimny simply because I had it in my Land-Cruiser. I would tow with it and I might consider a very mild tug but a full blooded gung ho lets show em how it's done is a big no no.
Roger
