Rustproofing.
20 Aug 2020 22:21 #227054 by jackonlyjack
Replied by jackonlyjack on topic Rustproofing.
Buzzweld do something called Lanoguard
not sure if it's what you're after
20 Aug 2020 23:01 #227055 by gv42
Replied by gv42 on topic Rustproofing.
Lanoguard have a YouTube Channel
02 Sep 2020 13:12 - 02 Sep 2020 13:15 #227644 by Bosanek
Replied by Bosanek on topic Rustproofing.
@Andy2640:
You appear to be quite mesmerized by a particular lanolin-based product.
While I believe that your appreciation for it is genuine and that you are not a paid promoter, I have strong doubts that you did a comprehensive comparative research of lanolin vs other types of vehicle rust proofing coatings.
You mentioned many advantages of lanolin (some of which are completely irrelevant for this application), but omitted to mention any disadvantages.
Here are some disadvantages and I would like to hear your comments on these:
1. While lanolin itself is harmless and food grade safe, many lanolin-based rust protection products contain various additives, which may not be. Therefore, it is quite assumptive to claim that application of lanolin based products is safe.
2. Some lanolin based products do not dry to a non-sticky resin, remaining sticky, thus attracting dirt and sand onto it, making a mess.
3. Not all lanolin based products are resistant to strong water jets. This is product dependent, as manufacturers balance between viscosity, creep performance, temperature resistance, abrasion resistance, self healing properties and elasticity. I highly doubt that most lanolin based products have this resistance.
4. How easy or hard is to remove old lanolin based coatings?
5. Does every lanolin based product have self-sealing properties?
6. And the biggest topic of all - does lanolin, being a type of wax, have any and which advantages against other high quality wax-based products for automotive rust protection on the market?
Conclusion:
While I do agree that Lanolin is certainly much better than any bitumen / tar or oil based product for this purpose, I am not entirely convinced that it is significantly better than other high quality wax based products. I am interested to know whether you have experience with other wax based products so that you can give us a comparative opinion of Lanolin against them. That is the pivotal point in my opinion.
P.S.: I am not trying to "debunk" you, but quite the opposite - to extract the best and to get the most realistic picture of the actual properties and expectations with that kind of product. I am also in the quest of determining the optimal method of underbody rust protection, and that world is full of misconceptions worldwide.
Last edit: 02 Sep 2020 13:15 by Bosanek. Reason: Added p.s.
02 Sep 2020 14:05 #227645 by lightning
Replied by lightning on topic Rustproofing.
Any rust preventative product that you apply under the vehicle will be better than nothing, so long as it's applied properly (as in, not over loose rust or moisture)
Just apply your favourite product, and be sure to check the coating annually/re-apply as necessary.
  • CC Baxter
02 Sep 2020 14:29 #227647 by CC Baxter
Replied by CC Baxter on topic Rustproofing.
I've just been experimenting with Andys' lanolin of choice on a boat trailer. The immediate impression, I don't like the smell! It's certainly as easy to apply as any other product I've used and once applied the appearance is similar. If the smell wears off in 2 or 3 weeks I'll be happier. I much prefer the machine oil smell of more conventional applications and the environmental benefits of lanolin aren't really floating my boat. Sorry Andy, but I gave it a go. Chris
02 Sep 2020 17:32 #227656 by Grim Reaper
Replied by Grim Reaper on topic Rustproofing.
I've done mine with Bilt Hamber Dynax, drove it home from the dealer and went at it with 3 different options, UB for the underbody, S50 for the cavities and anywhere not subject to harsh environment and UC for areas where I wanted to be able to see the components it was protecting (like the yellow OME dampers)
It took a while with a proper compressed air fed wax injection gun, but I'm very happy with the results and I rate Bilt Hamber stuff very highly
The following user(s) said Thank You: DAGZOOK
Time to create page: 0.122 seconds
