Rustproofing.
- Andy2640
07 Aug 2020 13:46 - 07 Aug 2020 13:48 #226234
by Andy2640
Replied by Andy2640 on topic Rustproofing.
I used Lanolin to protect my rig. The benefits are vast here's a list of pro's, I have found no cons, Yes seriously, its a wonder product in my eyes:
Hermetically seals the surface.
Proven to last 10 years as an anti seize grease on bolts in sea water.
Economical to use
Eco friendly.
Smells like lamberts farm yard
Is even food grade safe with some lanolin products (Prolan being one of them).
Used by militaries and farmers the world over. New zealand farmers love the stuff.
Will not jet wash off with commercial jet washers.
Dries to a semi hard resin (prolan).
Easy to apply, brush on or spray bottle or compressor, all work fine.
Use on electrical connectors, battery posts, the works, is dioelecttric, non conductive.
The Vikings used it on there ships, metal works and leather!!
Supports farmers Baaaaaaaa!!
Can be applied to light rust, eliminating the oxygen needed for corrosions progression.
Apply safely, no mess to worry about, drips in your hair and eyes, no problem.
No thick, smelly, horrible black oil to deal with. Seals for years and stays on no matter what.
One of the best natural anti corrosion products available in my eyes.
LOOK I EVEN EAT IN ON TOAST.
This is their thick pure lanolin grease. I use this on electrical connectors and battery terminals and my radious arm bolts. An amazing anti seize grease.
I used a lanolin called 'Prolan enduro heavy grade'. Bought from the withamgroup.co.uk in 5 litre quantity.
Simply one of the best products ive ever come across. So much so, i set up a FB page called the "lanolin appreciation society". Yepp im nuts!!
Economical to use
Eco friendly.
Last edit: 07 Aug 2020 13:48 by Andy2640.
- CC Baxter
07 Aug 2020 14:00 #226235
by CC Baxter
Replied by CC Baxter on topic Rustproofing.
Thanks Andy, I like the look of this. I think I'll get a can for experimental purposes.
Chris
Chris
- Andy2640
07 Aug 2020 14:33 #226236
by Andy2640
Good stuff CCB,
Keep me posted on this. Ive converted another chap to lanolin on FB too. He has now joined the lanolin appreciation society and has fell in love with this sticky sheep excrection aswell.
Nice1 CCB, let us know how you get on.
CC Baxter wrote: Thanks Andy, I like the look of this. I think I'll get a can for experimental purposes.
Chris
Good stuff CCB,
07 Aug 2020 14:50 - 07 Aug 2020 14:51 #226238
by lightning
Replied by lightning on topic Rustproofing.
Having owned Land Rovers for years, l am against clagging the underside of the vehicle with black "waxoyl" or similar products
All it does is, to cover up the rust and in some cases allow it to propagate behind the coating, which can make matters worse by effectively sealing in moisture. Our last Land Rover was "Dinitrol'd" and when l inspected it after a few years, rust was propagating behind the coating and large flakes of rusty steel could be scraped off.
I would use a spray grease or product such as XCP which is clear, and doesn't harden.
l looked under our 2020 Jimny and it does seem well protected as standard, but l will empty a few tins of XCP over the body mountings and inside the chassis rails.
Last edit: 07 Aug 2020 14:51 by lightning.
- Roger Fairclough
Topic Author
- Thank you received: 225
07 Aug 2020 15:18 #226240
by Roger Fairclough
Replied by Roger Fairclough on topic Rustproofing.
Panels have to be the body so that leaves the structure as the chassis.
Roger
Roger
07 Aug 2020 15:23 #226242
Replied by Soeley on topic Rustproofing.
A few links to Facebook public groups showing pictures of rust staining on relatively new cars.
m.facebook.com/groups/1007337742802763?v...&id=1419657618237438
m.facebook.com/groups/1480549812004311?v...&id=2970432803015997
Time to create page: 0.113 seconds
