Rustproofing.
- Roger Fairclough
Topic Author
- Thank you received: 225
06 Aug 2020 17:08 #226146
by Roger Fairclough
Rustproofing. was created by Roger Fairclough
Back in Feb. 2020 I emailed customer services at Suzuki with the question " what rust proofing measures are taken to protect the Jimny".I asked the question because the catalogue stated that the Jimny had a 12 year anti perforation warranty.
The response was:-
"Steel sheets are given corrosion resistance on the interior / and or exterior. These corrosion resistance steel sheet materials are called one of two -side galvanized steel sheets.
1.Steel sheets are treated with cathodic electro primer which is excellent in corrosion resistance.
2.Rust proof coatings are applied to door and side sill insides where moisture is liable to stay.
3.vinyl coating is applied to body underside and wheel housing inside.
4.Sealer is applied to door hem, engine compartment steel sheet to steel sheet joint, and the like portions to prevent water penetration and resulting in rust occurrence.
The 12 years is for penetration inside to outside and requires a dealer check and stamp every year between 11th-12th month
Roger
The response was:-
Roger
- Andy2640
06 Aug 2020 17:26 #226154
by Andy2640
Replied by Andy2640 on topic Rustproofing.
- Thank you received: 2004
06 Aug 2020 17:31 #226155
Replied by Lambert on topic Rustproofing.
That be as it may, an unprotected Jimny will be red raw with surface corruption within 18 months and there are many reported instances of mot failure for corrosion as early as 10 years.
- Roger Fairclough
Topic Author
06 Aug 2020 19:02 #226164
by Roger Fairclough
Replied by Roger Fairclough on topic Rustproofing.
The gen.4 has only been out for approx. 2 years, so I assume that the measures now taken by Suzuki are to rectify the problems they had with earlier models.
Roger
Roger
06 Aug 2020 19:12 #226166
Ok except for reports of new cars fresh off the ship already having surface corruption on supposedly sealed seams. As I did with my Dreadnaught I would apply a coating straight off the forecourt if I were in the market for a gen4.
06 Aug 2020 19:17 #226167
by Scimike
Replied by Scimike on topic Rustproofing.
You would think so, but pictures I have seen on here of some G4's have rust stains running from within the chassis, along with the normal weld seam surface rust and component rust starting. Looks very similar to a 1 year old G3 and Suzuki had a few attempts before the G3 to improve things. I personally would not believe the sale hype at this time, maybe in 10 years if they are still weld repair free.
Time to create page: 0.104 seconds
