Chinese Steel Bumpers: Installation
22 Mar 2020 22:00 #220164 by Rabid Rhino
X8GGY Cheers for the offer but next to my mates workshop is a global nuts n bolts supplier who lets us just get stuff once he's told us where they are.
AHTR...
2 holes on the right side dog leg bracket line up with 2 holes on the towing eye bracket.
But
There's only 1 hole on the left side dog leg bracket and it doesn't line up with anything. Did you drill any holes ?
  • X8GGY
22 Mar 2020 22:20 #220165 by X8GGY
Replied by X8GGY on topic Chinese Steel Bumpers: Installation
No Worries...
23 Mar 2020 00:00 - 23 Mar 2020 00:01 #220171 by ahtr
Rabid Rhino wrote: Missing a load of nuts and bolts from a torn open bag as the box was quite badly damaged.
Hopefully that's all I'm missing.
1 Dog leg bracket is on the car
What are the brackets below for & where do they go ?
I had no instructions. Drilled a few holes, just made it up as I went along, few extra bolts on the 'dog leg' brackets. Also where the 'dog leg' brackets bolt to the winch plate I drilled right through the chassis legs and bolted right through with some steel/spacers to strengthen it up.
The parts you've got left I just put in the scrap bin. The 2 bits on the left bolt onto the end of the chassis rails, then the winch plate is supposed to bolt to these using the big washers you have left. But like I said, I binned them and made up something myself as the fit wasn't great.
My green laner build
2003 Jimny - M16 engine - 4.16 TC - Winch - Snorkel - 30x9.5 Maxxis MT-764 tyres on 15x7 ET-7 offset wheels - 4" lift - Rear floating axles and discs
Last edit: 23 Mar 2020 00:01 by ahtr.
25 Mar 2020 00:38 #220240 by Rabid Rhino
ahtr, you got any close up pics of the corners, front & side on at the arches ?
I can't get the ends to line up with the arches. I'm out by about 0.5" there and under the lights there's a similar 0.5" gap.
The bumper won"t go any further back because its hitting the front edge of the lower slam panel.
So the only solution I can see is trim 0.5" of the rear top edge of the bumper
Trim the 0.5" here
  • Reason2doubt
26 Mar 2020 08:32 #220275 by Reason2doubt
Replied by Reason2doubt on topic Chinese Steel Bumpers: Installation
No instructions on mine either. Had some bits leftover but still couldn't think of where they could go so they got binned as well.
  • Reason2doubt
26 Mar 2020 08:33 - 26 Mar 2020 08:52 #220276 by Reason2doubt
I will get you some photos today as I need to do one of my essential food shops.
Edit: here you go - let me know if you want pictures of anything else!
[img
[img
[img
[img
Last edit: 26 Mar 2020 08:52 by Reason2doubt. Reason: Added photos
Time to create page: 0.205 seconds
