Chinese Steel Bumpers: Installation
18 Mar 2020 10:03 #220015 by Rabid Rhino
Has anyone fitted "Maiker OffRoad" bumpers similar to the pictures ?
I'm about to but a pevious owner cut my chassis so I'm curious to find out how they mount
  • X8GGY
18 Mar 2020 10:12 #220016 by X8GGY
Replied by X8GGY on topic Chinese Steel Bumpers: Installation
Can’t help... but LIKE them!
18 Mar 2020 10:39 - 18 Mar 2020 11:03 #220017 by Rabid Rhino
I'm asking because I'm about to install the bumpers but my chassis has been cut up by the previous owner
(I posted these pics in another post that stated I'm missing the ends but I don't know if they're needed for mounting the bumpers. I'm guessing they are.)
I'll be removing the poorly mounted front plate
Normal rear right side chassis, albeit for a slightly dented lower ice of u-channel
For some reason the previous owner replaced the u-channel with the lip under the end of the rear left side chassis with a flat level cut piece
Last edit: 18 Mar 2020 11:03 by Rabid Rhino.
  • Reason2doubt
18 Mar 2020 15:49 #220029 by Reason2doubt
Replied by Reason2doubt on topic Chinese Steel Bumpers: Installation
Hi RR, I have one installed. Here's a few snaps from back when I put it on. The bumper sits on-top of the original end-bits of the chassis. I suspect it would be too low if it wasn't sitting on them. I remember hammering the left side one to make it straight as I think it had taken a slight knock at some point. The picture where the whole front end painted in grey primer would have been before we painted it black and then bumper would have gone on so I am 100% sure we kept the bits that yours is missing.
[img
[img
[img
[img
[img
Not sure on the back bumper - only have the front one.
19 Mar 2020 13:23 #220066 by Rabid Rhino
R2D 2 things...
Thanks for the reply. Nice !!!!
Do you remember if it mounted to the front cross member ?
20 Mar 2020 11:52 #220085 by ahtr
Have installed a similar Chinese bumper on mine. I can't see you having a problem. From what I remember, it had 2 brackets that mounted on the outside of the 2 front chassis legs, then the winch tray bolted to them. I chose to beef up and add more bolts that went right through the chassis to strengthen it up at this point. I also had to make the slot for winch fairlead a bit larger and drill some holes to suit my winch.
The main bumper bolted to this winch plate with a couple of brackets, again, I added more of my own bolts and steel to strengthen everything up and get it fitting ok.
I also relocated my winch solenoid off the winch motor to under the bonnet, then made and ran new cabling in. This wasn't an issue as I planned to do this anyway.
Few finished pictures on build thread here HERE
My green laner build
2003 Jimny - M16 engine - 4.16 TC - Winch - Snorkel - 30x9.5 Maxxis MT-764 tyres on 15x7 ET-7 offset wheels - 4" lift - Rear floating axles and discs
Time to create page: 0.945 seconds
