Re:Recommended suspension kit 2" for New Jimny?
03 Apr 2020 16:10 #220634 by Soeley
This has been a very interesting read, thanks to the OP for opening the debate, and everyone else that has contributed. another thread shortcut-ted to easily find for future reference.
The following user(s) said Thank You: DAGZOOK
03 Apr 2020 19:31 #220652 by Busta
DAGZOOK, I would take the words of anyone who describes fitting brake lines as a "joy" with a pinch of salt :laugh: Sounds like they are doing the detail though!
It's interesting to hear claims of a longer shock with the same compressed length. I wonder where that extra 20mm of shaft goes? Or do the standard shocks not make full use of the available length? Either way, it seems like they could be used to gain some down travel even with standard springs.
I measured some old standard gen3 shocks today.
Measuring centre to base of threads on the fronts: 283 compressed, 403 extended, 120mm travel.
Measuring centre to centre on the rear: 302 compressed, 458 extended, 156mm travel.
03 Apr 2020 20:03 #220656 by DAGZOOK
Busta wrote: DAGZOOK, I would take the words of anyone who describes fitting brake lines as a "joy" with a pinch of salt :laugh: Sounds like they are doing the detail though!
Busta, humour me here.. If an aftermarket shock had a compressed length that was smaller than the OEM equivalent, the factory bump stop would prevent the shock from ever bottoming out? additional bump stops are then only required if the compressed length of an aftermarket shock is greater than the OEM equivalent, because your shock would bottom out before the bump stop engaged (das ist kaput) ? :woohoo:
Praise the lord for this forum - this damn virus is making me loose my mind!
03 Apr 2020 20:11 #220658 by DAGZOOK
This guy is fitting a 'Gabriel' 2" lift kit to a gen.3 - his rear shocks are longer than OEM but have the same compressed length. Skip to 20.53 :whistle:
03 Apr 2020 20:22 #220659 by Busta
DAGZOOK wrote: Busta, humour me here.. If an aftermarket shock had a compressed length that was smaller than the OEM equivalent, the factory bump stop would prevent the shock from ever bottoming out? additional bump stops are then only required if the compressed length of an aftermarket shock is greater than the OEM equivalent, because your shock would bottom out before the bump stop engaged (das ist kaput) ? :woohoo:
Correct, yes. So given trailmaster are providing extended bump stops, their shocks must be longer when compressed than standard. Which is what you would typically expect from a longer shock.
03 Apr 2020 20:28 #220660 by Busta
DAGZOOK wrote: This guy is fitting a 'Gabriel' 2" lift kit to a gen.3 - his rear shocks are longer than OEM but have the same compressed length. Skip to 20.53 :whistle:
That's really interesting. Thanks! I've always liked the idea of a close-to-standard height lift kit that uses longer but softer springs to give a soft ride and more flex, but assumed I'd need to sacrifice some up-travel to gain down travel. That proves otherwise. I just need some custom wound springs now then!
Time to create page: 0.489 seconds
