Lockright tips
  • funkyjimny
  • 2004 jimny soft top, factory hardtop, ARB bumper
11 Jun 2014 15:15 #117633 by funkyjimny
Replied by funkyjimny on topic Lockright tips
No, could be OK, make sure its in 2wd and try a gentle bend left then right and you should hear a gentle clicking from the diff as it unlocks, if not its too tight.
richmondgear.com/index.php/installation-manuals
Gary
  • TomDK
11 Jun 2014 15:16 #117634 by TomDK
Replied by TomDK on topic Lockright tips
Thanks will give it a try :)
  • TomDK
11 Jun 2014 19:34 #117658 by TomDK
Looks like I will have to take it all apart and try again.
Have lifted one wheel off ground and can't rotate it a bit, not even by force.
So I will probably have to grind the pinion joint down as well.
Not sure what Supergaz means with using the original shims instead of the ones provided with the Lockright kit, as the original diff only has shims on the outside of the side gears.
Or should I start by removing the original shims on the outside of the side gears?
  • RichiesJimny
11 Jun 2014 19:41 #117660 by RichiesJimny
Replied by RichiesJimny on topic Lockright tips
Put the car in gear jack up one wheel and try and turn it by hand it should turn freely with a clicking sound from the diff (you may need to rock the wheel backwards and forwards to unlock it) if it is too tight remove the two thicker shims.
  • TomDK
11 Jun 2014 19:43 #117661 by TomDK
RichiesJimny wrote: Put the car in gear jack up one wheel and try and turn it by hand it should turn freely with a clicking sound from the diff (you may need to rock the wheel backwards and forwards to unlock it) if it is too tight remove the two thicker shims.
Just to be sure, you mean the thick shims that came with the kit?
  • RichiesJimny
11 Jun 2014 19:45 #117662 by RichiesJimny
You reposted while I was typing :laugh:
Strip down the diff and remove the thicker shims on both side gears also make sure you have swapped the side gears round.
Time to create page: 0.094 seconds
