A Snorkle really
  • idiotmobil
13 May 2014 16:58 #115102 by idiotmobil
Replied by idiotmobil on topic A Snorkle really
Bigjim91 wrote:
Basketcase wrote: My girlfriend and myself have a modified jimny each both have a snorkel no other breathers and both love a good swim, you occasionally get an engine light on the dash but it clears itself the day after haven't had any trouble what so ever with water related problems
Mite wanna Chang pe ya oils after doin that, also water won't effect 12 volts
but it will speed up the connectors failing due to corrosion ive put some marine connector protector all over mine
  • jonesyba420
13 May 2014 17:00 #115103 by jonesyba420
Replied by jonesyba420 on topic A Snorkle really
idiotmobil wrote:
jonesyba420 wrote: Obviously a snorkel is useless without extended breathers all round.
as for the electrics they seem to cope fine have seen jimnys driving through rivers with water levels upto the windscreen with no issues.
I regularly liberally spray all the connectors etc with wd40............... builds up a dirt/wd40 barrier.
would that be this fine jimny
It certainly would be Sam B)
  • Bigjim91
13 May 2014 17:00 #115104 by Bigjim91
Replied by Bigjim91 on topic A Snorkle really
No way, bin doin it for years
  • Keefe
13 May 2014 19:33 - 13 May 2014 19:34 #115125 by Keefe
Replied by Keefe on topic A Snorkle really
I wouldn't use WD40 too much. It makes a right mess eventually.
Also, I've read somewhere that the RN or some nautical group have stopped using it 'cause it has been known to cause fatigue or something to plastics/rubbers surrounding the electrical contacts, so they use something else???
Don't know how true/factual that is but there's nothing on the telly and my medication hasn't kicked in.
Anyway.....
Last edit: 13 May 2014 19:34 by Keefe.
13 May 2014 19:36 #115126 by mlines
Replied by mlines on topic A Snorkle really
Bigjim91 wrote: also water won't effect 12 volts
The trouble is that it will affect the few 100,000volts on the ignition system. This is under the plastic cover on top of the engine and it open at one end. Therefore it is good against some quite serious splashes but once water enters the end of the cover is basically game over.
  • Dave cc
13 May 2014 20:27 #115134 by Dave cc
Replied by Dave cc on topic A Snorkle really
Keefe wrote: I wouldn't use WD40 too much. It makes a right mess eventually.
Anyway.....
Ohhhh would that be a Isuzu diesel by any chance
Time to create page: 0.203 seconds
