A Snorkle really
  • RichiesJimny
13 May 2014 23:19 #115159 by RichiesJimny
Replied by RichiesJimny on topic A Snorkle really
I wonder if they do snorkels for audi's
  • ZookFastback
13 May 2014 23:25 #115160 by ZookFastback
Replied by ZookFastback on topic A Snorkle really
The snorkel is for other purposes as well as stopping water ingress. Dust protection for instance. Probably not a problem in wet UK but down here in Oz it is a real motor killer. Just Having the snorkel up high where there is less dust, particularly in convoy on outback trips, makes a huge difference to the life of filters. Also, many of us fit pre-filters on top of the snorkels to catch the courser things like bugs and grasshoppers and there always seems to be locust plagues in Summer. I've had to empty my pre-filter 2-3 times on a bad day because of dust and locusts so they are a real protective measure.
  • TLW
14 May 2014 03:59 #115163 by TLW
Replied by TLW on topic A Snorkle really
Doesn't happen instantly, takes a while, but WD40 will definitely eat or soften, rot and turn to goo some rubbers and plastics. I've seen it happen. Most electrical insulation seems at least fairly proof against it though.
As a barrier against water, rather than to shift it out of a damp contact, waterproof white grease works pretty well, and there are water resistant silicone based electrical sealers specifically designed to keep water out.
14 May 2014 09:24 #115180 by Busta
Replied by Busta on topic A Snorkle really
ZookFastback wrote: The snorkel is for other purposes as well as stopping water ingress. Dust protection for instance. Probably not a problem in wet UK but down here in Oz it is a real motor killer. Just Having the snorkel up high where there is less dust, particularly in convoy on outback trips, makes a huge difference to the life of filters. Also, many of us fit pre-filters on top of the snorkels to catch the courser things like bugs and grasshoppers and there always seems to be locust plagues in Summer. I've had to empty my pre-filter 2-3 times on a bad day because of dust and locusts so they are a real protective measure.
I helped a friend in WA (He runs a sheep station near Carnarvon) choose a new ute and we talked about snorkels and dust from convoys etc. We eventually decided that when you're following someone it can't be any better with a snorkel because it's still sucking dusty air. When you're driving through red dust, you get red dust everywhere right?! Raising the air intake 60cm isn't going to make much difference. The only way to avoid the dust is follow a loooong way behind!
5 years later I was back over there and he's still got the ute (a Rodeo) and said it's no worse without a snorkel than the previous utes he's had with one.
That's without a pre-cleaner though, and I could see that making a difference.
In the UK as with Landrovers, the majority of Jimnys you see with snorkels will never actually be in a situation where they need it. Most people just like the look. The same is true of a lot of modifications.
  • jonesyba420
14 May 2014 09:56 #115187 by jonesyba420
Replied by jonesyba420 on topic A Snorkle really
I see my snorkel as "just in case" device.
