diff guards
- jonesyba420
- Visitor
TLW wrote: Anything that hangs off the diff casing bolts must stand a chance of damaging the diff case or axle - a guard that transfers any pressure or impact into the diff/axle case and bends it might be worse than no guard at all.
this had crossed my mind, kap suzuki are meant to be one of the leading suzuki modifying companies so youd hope theyve thought of that! !
if I design one it will look very similar but ill use the bottom 4 bolts on the diff rather than 3 like theirs. So hopefully it will spread any load abit better as it will be mounted to effectively half the diff.
- jonesyba420
- Visitor
steffan wrote: I used ep 75/90 most decent motor spairs keep it
thanks buddy. Do you know how much it takes or is it a case of fill it till it overflows?
- GuardianAngel
- Visitor
Fill till it starts to spill out.
- jonesyba420
- Visitor
- jonesyba420
- Visitor
Did you make a typo as my local wilco only had ep75/80 gear oil.is that the right one?
- jonesyba420
- Visitor
