sj413 / samurai
  • adamjimny
20 Dec 2012 21:14 #55867 by adamjimny
sj413 / samurai was created by adamjimny
how wide is the front axle? im wanting to swap the jimny unit for one as the diff's are stronger. how wide is the jimny one also?
i keep snapping teeth of the spider gears in the diff. if i cant find out or get hd ones then ill have to put in a difflock just for strength but id rather not due to cost and i like the challenge with open diffs
any help would be great
cheers
Adam
  • Smoggy
20 Dec 2012 21:32 #55872 by Smoggy
Replied by Smoggy on topic sj413 / samurai
Dunno how much wider it is but I can measure the width of my SJ front axle tomorrow for you if you like. I changed mine to SJ for the same reason and also that you can buy chromo 4340 shafts and cvs for the sj.
  • adamjimny
20 Dec 2012 22:15 #55887 by adamjimny
Replied by adamjimny on topic Re: sj413 / samurai
Id be gratefull if you could pal in mm's if poss or cm's cheers
Sent from my GT-I9100 using Tapatalk 2
  • Smoggy
20 Dec 2012 22:26 #55890 by Smoggy
Il do it tomorrow mate. Remind me tomorrow night if I forget :cheer:
  • adamjimny
20 Dec 2012 22:39 #55891 by adamjimny
Cheers pal. Measure to iside edge of the ball part what the steering swivals over/on. Just so i can see if they are narrower or wider etc
Cheers
21 Dec 2012 08:28 - 21 Dec 2012 08:30 #55905 by kirkynut
Replied by kirkynut on topic Re: sj413 / samurai
You must be going some to keep blowing Jimny front diffs, cv's yes but diffs, Crickey!
How are you doing it? Flying the front in the air and landing with the front wheels spinning at full chat?
If so, there is an easier way of fixing the problem but it involves you changing not the car changing.
What size tyres are you using when you do this and what tread pattern. I have used mine at our club and even with Little Miss Dangerous (my Mrs with no mechanical sympathy) driving and abusing it with nearly 30" Malatesta Kaimans on it we have only managed to do one Cv in all the years we've had it!
I know that are only 2 pin in the front. Have you asked someone like Rockwatt if pegging them is possible and if it will stop this. Or can the parts be heat treated or criogenically treated to make them last longer. I don't know if this works with gears etc. Worth an ask though. Probably cheaper than getting an ARB just for strength.
Adjusting driving style is cheaper though. I know people who won the Scorpion Challenge in a Landrover running standard shafts and cvs. So driving style counts for a lot and it doesn't mean less success.
Last edit: 21 Dec 2012 08:30 by kirkynut. Reason: adding
Time to create page: 0.153 seconds
