sj413 / samurai
  • darthloachie
21 Dec 2012 23:16 #55950 by darthloachie
Replied by darthloachie on topic sj413 / samurai
even with diff locks its not boring when you're trying to follow a guy with a 600 bhp jeep!!!
  • adamjimny
22 Dec 2012 08:04 #55963 by adamjimny
Replied by adamjimny on topic sj413 / samurai
yeah ill look into yota axles or similar. i was hoping for less hassle but it may be the only way cheers guys
  • adamjimny
23 Dec 2012 14:32 #56048 by adamjimny
the only reason i would fit difflocks would be for if i got stuck so it helped to get unstuck but i like the challenge of really thinking about the line i have to choose
  • TomDK
23 Dec 2012 22:53 #56079 by TomDK
Replied by TomDK on topic sj413 / samurai
adamjimny wrote: the only reason i would fit difflocks would be for if i got stuck so it helped to get unstuck but i like the challenge of really thinking about the line i have to choose
Or driving some harder terrain or competitions? B)
  • adamjimny
25 Dec 2012 22:35 #56208 by adamjimny
panosd wrote: The swaping is not easy. The front axle of the samurai is stronger than the jimny one. The rear are the same.
Also samurai axles are norower than jimny ones. You are going to need 2 pairs of wheel spacers at each side
to get them sorted with the rears.
Also you will have to make new coil and radious arms brackets on the sami axle, measure and adjust caster,
fix steering bars, front and rear of axle.
90% you wont be happy with the result, if jimny is your daily car.
If you have it only for off-road its ok.
I suggest you get a set of HD front axle shafts and cv's , and make some axle strength parts like ora's.
I have on my own a set of insa turbo special tracks 235/85/16 with front hd axleshafts and cv joints and its ok.
I run a 4.9 t-case and arb's on both axles.
im not breaking cv's or halfshafts.....still on originals from new its the spider gears (planet gears) thats are snapping thats all but means i need to buy a whole diff just for these parts....i may look into land rover axles or similar
25 Dec 2012 23:20 #56209 by kirkynut
Replied by kirkynut on topic sj413 / samurai
It is odd your are breaking the diff gears but not CV's. I wonder if there is another issue causing this.
What diff oil are you using and what level do you keep it at. It's just you are the first person I've read having diff problems before CV's or at all for that matter!
Time to create page: 0.717 seconds
