sj413 / samurai
  • Paul4x4
21 Dec 2012 09:09 #55910 by Paul4x4
Replied by Paul4x4 on topic sj413 / samurai
Haven't measured anything, but the track width found in these trucks technical data should be the same as the axle width, measured with 0 offset wheels.
So, on SJ413 it's around ~1210mm, Samurai ~1310mm and Jimny ~1355.
And keep in mind that only the very last Samurai models(coil sprung models) had a high pinion front axle like Jimny's, if that has any significance to you.
  • adamjimny
21 Dec 2012 13:13 #55915 by adamjimny
Replied by adamjimny on topic sj413 / samurai
kirkynut
it is when a wheel lifts but without the heavy foot as i prefer to be carefull if i can its due to running 32.5" special tracks that realistically measure at 33.5" so has a lot of grip/rotational force.
im considering getting some samurai axles (both) and putting hd shafts and lockers in for strength i was looking to see if i could have a 'quick fix' for the time being.
21 Dec 2012 14:19 #55917 by maverick
Replied by maverick on topic sj413 / samurai
maybe you need to start looking at Toyota axles ...
Jalapeño, IISY?
  • panosd
21 Dec 2012 14:20 #55918 by panosd
Replied by panosd on topic sj413 / samurai
The swaping is not easy. The front axle of the samurai is stronger than the jimny one. The rear are the same.
Also samurai axles are norower than jimny ones. You are going to need 2 pairs of wheel spacers at each side
to get them sorted with the rears.
Also you will have to make new coil and radious arms brackets on the sami axle, measure and adjust caster,
fix steering bars, front and rear of axle.
90% you wont be happy with the result, if jimny is your daily car.
If you have it only for off-road its ok.
I suggest you get a set of HD front axle shafts and cv's , and make some axle strength parts like ora's.
I have on my own a set of insa turbo special tracks 235/85/16 with front hd axleshafts and cv joints and its ok.
I run a 4.9 t-case and arb's on both axles.
  • TomDK
21 Dec 2012 14:28 #55919 by TomDK
Replied by TomDK on topic sj413 / samurai
adamjimny wrote: kirkynut
Yup.. I very much understand why you want Samurai axles fitted. I know a user here on Bigjimny forum, Frede.gv1, Is fitting Samurai axles to his Jimny sometime next year.
And it's not all about driving style.
I know you can compete on local club level in beginner classes. But try find a truck with standard axles in Croatia Trophy top 10 .. Or any similar 4x4 Trophy/Challenge B)
21 Dec 2012 17:04 - 21 Dec 2012 18:32 #55928 by kirkynut
Replied by kirkynut on topic sj413 / samurai
It's not all about driving style, I do appreciate that and with 33" extreme tyres it is perhaps understable really. I think that combination is weaker than my mate's standard Landrover shafts and Cvs which at that time probably also ran 33" tyres.
Tomdk - The Scorpion Challenge was the most extreme Winch Challenge event in the UK with only the top teams daring to compete and it was the likes of them who competed in the Croatia Trophy back then. He and his co-driver are very clever people and know when to drive and when to winch and think outside the box, avoiding damage to the truck and it's drive train.
It changed It's name to the Howling Wolf, which you may have heard of but was the same event.
I think I agree with Maverick in this instance in that Yota axles might be the best way forward. Especially if you can get a rear one with It's standard electric rear locker!
Speak to Rob Butler or Rhino Ray as they are masters of fitting them go Zukes.
Edit: scrub the bit about getting a rear standard locker as I remember from the start you like the challenge of open diffs. I agree, they are more fun in the long run and stop you creating a truck that is so capable It's boring!
Last edit: 21 Dec 2012 18:32 by kirkynut.
Time to create page: 0.242 seconds
