vibrations ! !
13 Feb 2012 16:21 #33410 by Obarno
Replied by Obarno on topic Re: vibrations ! !
I had a lot of vibration with my rocklobster box conversion and ORA gearbox mounts - I had the 3 piece red bushes. The problem, I think, is that the bushes are very hard and it has a bolt all the way through which inevitably will touch both the gearbox mount and chassis mount at some point. Hence vibration will be transmitted. Like you I use my Jimny a lot on the road and found it very unpleasant to drive. I had a short prop made for it between the autobox and rocklobster, and thinking there was a problem with it had it remade but the problem persisted. In the end I changed back to standard Suzuki rubber mounts and its now much better to drive with almost no vibration. So I suppose if you want strong mounts you have to put up with vibration, if you want a more smooth drive use Suzuki originals. I do carry a spare one of those with me and although I don't do anything really challenging with this car I haven't broken one (yet!)
With my French car which I use for tougher off roading I use Llama bolt through mounts which have rubber bushes (on a rocklobster transfer box) and these seem to work much better. They are nearly as good as the original mounts in terms of vibration, but of course should be stronger.
  • ooky_123
15 Feb 2012 14:51 - 15 Feb 2012 14:52 #33533 by ooky_123
Replied by ooky_123 on topic Re: vibrations ! !
are you using all 3 of the transfer box mounting bushes ?
I had issues when I mounted mine as the mini prop was fouling the transmission tunnel.
In the end, I reduced the number of bushes down to find the optimum
Last edit: 15 Feb 2012 14:52 by ooky_123.
15 Feb 2012 15:53 #33538 by Obarno
Hi Ooky - I think, from your photo, that you have the bushes on incorrectly. As I understand it there should be the large bush between the chassis mount and the gearbox bracket, with one of the other mounts below the chassis mount , and one above the gearbox bracket, if that makes sense! the bolt then passes through all 3. I can see why the prop hit the tunnel as the transfer box would be mounted very high and unless you have a body lift the transfer box would have been hitting the underside of the tunnel.
  • bigoffroader
15 Feb 2012 16:14 #33539 by bigoffroader
Replied by bigoffroader on topic Re: vibrations ! !
Is your input prop catching the gearbox mounts as it sounds like it
  • ooky_123
15 Feb 2012 16:29 #33542 by ooky_123
Obarno wrote: Hi Ooky - I think, from your photo, that you have the bushes on incorrectly. As I understand it there should be the large bush between the chassis mount and the gearbox bracket, with one of the other mounts below the chassis mount , and one above the gearbox bracket, if that makes sense! the bolt then passes through all 3. I can see why the prop hit the tunnel as the transfer box would be mounted very high and unless you have a body lift the transfer box would have been hitting the underside of the tunnel.
Nope, tried that too .. that was the first setup, and the transfer box mount touched the chassis.
Ive tried every combination and this was the only one that gave me clearance on the chassis and also gave enough clearance for the mini prop
15 Feb 2012 17:09 - 15 Feb 2012 17:11 #33544 by Johnniehec
Replied by Johnniehec on topic Re: vibrations ! !
I'd agree with Obarno, if either the nut or bolt is in contact with metal you'll get vibration, personally I'd go for three of these.
compare.ebay.co.uk/like/190633345733?var...ceItemTypes&var=sbar
Last edit: 15 Feb 2012 17:11 by Johnniehec.
Time to create page: 0.101 seconds
