Where's best to get a Lock Rite?
  • kenway
  • Visitor
  • Visitor
30 Apr 2011 12:45 #15671 by kenway
Replied by kenway on topic Re: Where's best to get a Lock Rite?
Thanks that puts my mind at rest. Having a read of the user manual it says you can use a heavier weight gear oil which I've done and its made it almost silent. Probably won't be perfect for the bearings but for the 3000 miles I do a year in it perfect for me. Hope this helps some of you.
  • Ranster
  • Visitor
  • Visitor
02 May 2011 14:27 - 02 May 2011 14:29 #15772 by Ranster
Replied by Ranster on topic Re: Where's best to get a Lock Rite?
Short mov of my Jimny equipped with lockright 1510 on an axle twister.
Last edit: 02 May 2011 14:29 by Ranster.
  • Bigchridy
  • Visitor
  • Visitor
03 May 2011 13:19 #15809 by Bigchridy
Replied by Bigchridy on topic Re: Where's best to get a Lock Rite?
kenway wrote: Thanks that puts my mind at rest. Having a read of the user manual it says you can use a heavier weight gear oil which I've done and its made it almost silent. Probably won't be perfect for the bearings but for the 3000 miles I do a year in it perfect for me. Hope this helps some of you.
What type of oil did you use? I used the standard type oil in mine and it works fine but if I can make it slightly quieter that would be great.
Chris
  • vitara_mad
  • Visitor
  • Visitor
03 May 2011 14:17 #15815 by vitara_mad
Replied by vitara_mad on topic Re: Where's best to get a Lock Rite?
you don't need any special oil with a lockright
  • kenway
  • Visitor
  • Visitor
07 May 2011 13:55 #16008 by kenway
Having problems with my lock rite - I reversed on the drive and heard a bang. Taking it apart I saw that the 4 location pins had sheared. :ohmy: After ordering new pins and fitting these and testing the lock rite its still not working. :( Wondered if anyone has had any problems or can make suggestions on how I can solve the problem. It is on an '06 Jimny. Cheers.
  • kenway
  • Visitor
  • Visitor
10 May 2011 15:53 #16140 by kenway
I stripped my rear diff down again and found the pins had sheared again - see pictures...
Attachment Photo0083.jpg not found
Attachment Photo0082.jpg not found
After this I tried to contact through phone and email tech support but had no reply. As you can see from the rest of the pictures it is not worn and I'm stumped as to why this is happening.
This is how the pins and springs were inserted and the only pin which has survived.
Attachment Photo0084.jpg not found
Is it just an expensive paperweight?! Any help would be fantastic.
Attachment Photo0081.jpg not found
Attachment Photo0085.jpg not found
  • gazert
  • Visitor
  • Visitor
10 May 2011 17:55 #16162 by gazert
Replied by gazert on topic Re: Where's best to get a Lock Rite?
Sounds shit times mate.
No idea tbh but hope u get it sorted!
  • Bigchridy
  • Visitor
  • Visitor
10 May 2011 18:08 #16165 by Bigchridy
kenway wrote: I stripped my rear diff down again and found the pins had sheared again - see pictures...
From the pics it looks like you have used the 2 big washers supplied with the Lock right. I have not used these. Instead I only used the 2 thin washers already in the existing differential.
Since fitting I dont seem to have had any big issues with the Lock right. I've had a couple of big clunks but the diff is still locking and unlocking as it should.
Hope this helps
Chris
  • Bigchridy
  • Visitor
  • Visitor
10 May 2011 18:12 #16166 by Bigchridy
Also see this link as it shows which washers should be used.
www.jimny.se/locker.html
Chris
  • kenway
  • Visitor
  • Visitor
10 May 2011 18:28 #16168 by kenway
I didn't use the thick thrust washer but did you not put in the spacer between the pinion block and the slide gear? This is where I may be going wrong. All information is helpful! Thanks for the advice so far.
  • kenway
  • Visitor
  • Visitor
11 May 2011 14:16 #16201 by kenway
... so if I leave out the spacer that comes with the lock rite, will it not shear the pins? All help is welcome.
  • Bigchridy
  • Visitor
  • Visitor
11 May 2011 18:46 - 11 May 2011 18:49 #16207 by Bigchridy
I followed that link exactly as I've never really come accross diff locks so thought I would get some advise 1st!:)
Have you been putting the square pinion joint back in the diff with the lock right?
The only 2 things I can think of at the moment are that either the wrong spacers have been used or the square joint has not been fitted.
Hope this helps
Chris
Last edit: 11 May 2011 18:49 by Bigchridy.
