Where's best to get a Lock Rite?
- gazert
- Visitor
The only thing I can think is the rear of the diff case is not bolt off it's welded! Can u get in from the front side?
Nice thing to have:woohoo:
Andy
- biggaz
- Visitor
Dont have funds at the moment anndd
dont think id have the skill to fit?
- supergaz
- Visitor
As a specialist brake tester engineer for Gemco, i've witnessed the results of testing brakes with a diff lock engaged on a lorry, not good!
The test procedure is to test each side individually to max force which will blow a diff, then they start both sides to test for imbalance which is ok, except for an LSD which a specialist 4x4 brake tester is required which can reverse 1 roller. These are found mainly in VAG dealerships to test cars such as a 4 motion /quattro VW / Audi ect. Never test the brakes with a diff lock engaged.
Just a little warning guys.
- bluejimny
- Visitor
- Bigchridy
- Visitor
Gary Whenmouth wrote: Just make sure you tell your MOT man before they test the brakes! Or it is goodbye diff
Decelerometer it is then!
To be honest I never even thought about brake testing with a lock right fit. I'm glad you mentioned this could have been expensive!!
Chris
- supergaz
- Visitor
- Bigchridy
- Visitor
I think one of us must have got our wires crossed. I'm an MOT tester and we still have a decelerometer at work for use on 4x4's with permanent 4 wheel drive. Also on my MOT training 2 years ago we were shown how to use a decelerometer for this purpose.Gary Whenmouth wrote: I realy want to lock my rear diff! but as a brake tester engineer I know its a no no unless it can be disabled for the MOT. A decelerometer is still used in the trade, but not for MOT use.
You may be right and this might of changed but VOSA havent informed any of the testers at my place. It's not something we use every day as its rare that we will get a 4x4 to MOT unless its one of mine!
Chris
- supergaz
- Visitor
At least we have addressed the problem of blowing a diff if the tested is unaware of a locked dif. MOT stations for class 2 are generally poorly equipped to cater for 4x4's, As some of my collegues cater for sites such as Kwick-fits/dealerships.
Just had a quote from the Powertrax European distributor of £290 +p+p each :laugh: :laugh:
So its off to the USA.
I will give it a couple more days to see if anyone else is "in" then I will send out the requests for monies.
The monies will be held until everyone has pais, if we fail to make the quota then the monies will be returned in full.
Once the order has been placed there will be no going back, so no refunds once the full order has been placed.
- Bigchridy
- Visitor
The money is waiting so I'm ready whenever you are!
Chris
- Brian.SMC
- Visitor
Brian
