Mounting rock sliders/side steps??
- Monkey
23 Feb 2011 12:02 #12045
by Monkey
Replied by Monkey on topic Re: Mounting rock sliders/side steps??
23 Feb 2011 18:44 #12064
by kirkynut
Replied by kirkynut on topic Re: Mounting rock sliders/side steps??
You appear to have it sorted but if you have not gone into production of them yet it mght be worth having an email chat with Darren at KAP Suzuki and / or Rob at Off Road Armoury here in the UK.
I know Darren was looking at having some bolt on Rock Sliders made up from when I made enquiries some time ago. I don't know how far he got. I have welded on ones though.
Rob Butler at Off Road Armoury is a helpful chap and I'm sure has looked at the idea in the past.
They maybe able to tel you what some of the pitfalls are before you make yours so you can draw from their experience and save you from making mistakes they have already made or tell you that something won't work from calculations they've made with kit you don't have access to.
Hope this helps
Hope this helps
23 Feb 2011 20:03 #12076
by mcjimny
Replied by mcjimny on topic Re: Mounting rock sliders/side steps??
The showy side steps i had on when i first bought mine were bolted to the long body bolts that protrude underneath then had brackets around the chassis. The bolts stopped them moving front to back but the brackets were so weak that they soon got bent when i got hooked up on them. Something beefier and lower profile should work
- Monkey
23 Feb 2011 20:24 #12081
by Monkey
Mhh..thanks guys.
A few of my mates have built there's similar to them, but i thought i might just add a gusset for a bit of overkill.
24 Feb 2011 08:48 - 24 Feb 2011 08:49 #12090
by dirtydogz
How about a bracket like this it maybe a lot stronger.
BAZ.
2002 JLX Soft Top
Replied by dirtydogz on topic Re: Mounting rock sliders/side steps??
Attachment scan0001_2011-02-24.jpg not found
BAZ.
2002 JLX Soft Top
Last edit: 24 Feb 2011 08:49 by dirtydogz.
- Monkey
24 Feb 2011 10:12 #12091
by Monkey
Yes in theory that will be very strong, but don't forget you have brake line's or some other lines running down the chassis rail on the driver's side, so this would only work on the passenger side.
Time to create page: 0.187 seconds
