Mounting rock sliders/side steps??
10 Mar 2011 10:10 #12975
by dirtydogz
2002 JLX Soft Top
Replied by dirtydogz on topic Re: Mounting rock sliders/side steps??
maybe you could take some photos as you make them it might help some one if they need to make some for there jimny.
DIRTYDOGZ
DIRTYDOGZ
2002 JLX Soft Top
- Monkey
10 Mar 2011 10:15 #12976
by Monkey
Replied by Monkey on topic Re: Mounting rock sliders/side steps??
Yep for sure!
10 Mar 2011 10:36 - 10 Mar 2011 10:40 #12977
by dirtydogz
2002 JLX Soft Top
See you live in Perth, I lived in Vic park in the 1960 on the canning highway happy day :woohoo:
2002 JLX Soft Top
Last edit: 10 Mar 2011 10:40 by dirtydogz.
- Monkey
10 Mar 2011 10:44 #12978
by Monkey
Wow! 1960's
Perth has changed a lot sense then.
10 Mar 2011 10:51 - 10 Mar 2011 10:55 #12979
by dirtydogz
2002 JLX Soft Top
So have i alot older.
Off to work now so have a good day.
2002 JLX Soft Top
Last edit: 10 Mar 2011 10:55 by dirtydogz.
14 May 2011 16:31 #16321
Replied by mlines on topic Re: Mounting rock sliders/side steps??
I have been looking into this and have a couple of questions.
1. How did you find a "clamping point" on the drivers side of the vehicle. The chassis rail has the axle mounting points at either end, the cross chassis tubes and the transfer box mounts and mounting bar. I cannot see any place you can feed a clamp around the chassis on the drivers side.
2. How did you fit the clamps and bolts between the chassis rail and the body (do you have a body lift). At some points there is less than 10mm space. The only position where there seems to be adequate space is around a floor rise that occurs mid chassis rail, just by the transfer box mount?
Time to create page: 0.171 seconds
