lightweight buggy
- X8GGY
27 Aug 2021 11:53 #237923
Replied by X8GGY on topic Re:lightweight buggy
OOOooh!
You're ahead of me now... mine's still amassing parts and brain ticking...
Following!
Dave
Following!
Dave
- Baloo
28 Aug 2021 06:52 #237940
by Baloo
Replied by Baloo on topic Re:lightweight buggy
OOOooh!
Following!
Dave
my brain is still ticking too, im thinking front wheel drive engine and box mounted amidship with one
driveshaft to the front axle and the other to the back axle, need the smallest lightest engine i can find, did they used to make a 3 cylinder corsa at one point ??
- Thank you received: 2005
28 Aug 2021 07:34 #237944
Replied by Lambert on topic Re:lightweight buggy
There are plenty of quite fruity 3 cylinder turbo fwd motors out there now in the city car segment.
- Baloo
28 Aug 2021 17:19 #237962
by Baloo
I should have put cheap in my list of requirements lol
I have just perused ebay and can't find any cheap 3 cylinder engines, how about mgf the k series is all aluminium isn't it, I know they have a history of hg failure but that's curable, they seem cheap enough ?
- X8GGY
29 Aug 2021 07:38 #237981
If you use a transverse engine longitudely you've effectively got a centre diff as well, unless you can weld it up?
- Baloo
29 Aug 2021 08:54 - 29 Aug 2021 10:21 #237989
by Baloo
Morning Dave
yes just weld it up like any diff easy peasy then i have a 4 to one transfer box with out the cost of buying one
I'm looking at engines with cvt gearboxes as you only have 1 long gear with no gear changes to upset traction when crawling , mgf have one as do Nissan micra and probably many other manufactures will see what turns up cheap
Last edit: 29 Aug 2021 10:21 by Baloo.
Time to create page: 0.186 seconds
