lightweight buggy
- Baloo
01 Oct 2021 07:27 #239030
by Baloo
Replied by Baloo on topic lightweight buggy
Hi
well my first thought was making a drive through axle by mounting another diff on the back of the first rear axle like they used to back in the day
space was my concern also but effectively if you use 31" tyres then youve got around 31" of space from axle to axle so it should be possible ?
hadent really considered a drop box as i guess i would have to make it from scratch
- Baloo
01 Oct 2021 07:33 #239031
by Baloo
then i found myself looking at a vitara gearbox that was on the workshop floor
looking at the front output shaft down low i would imagine it would be possible to machine the housing of the back end and make a new double ended shaft so that you had a flange facing forward and backwards driving the front and middle axle and then use the original rear out put in the centre top position to drive the rearmost axle, it maybe an idea to flip the last axle upside down so the diff was on the passenger side to help with propshaft clearences does that make sense ??
- Baloo
01 Oct 2021 07:36 #239032
by Baloo
and then i moved onto the twin side by side transfer box idea which i think offers most merit
will have to draw that i dont think i can explain it lol
- Baloo
01 Oct 2021 07:45 #239036
by Baloo
ok, all I can see is baby oil and power tools, what am I missing?
is that baby oil will check when im at the workshop later today
02 Oct 2021 09:51 #239065
by LesNewell
Replied by LesNewell on topic lightweight buggy
Lots of progress there. I'm sure you'll find a use for those gas shocks. A 3 wheeler maybe? Or you just one side of a 6 wheeler
As far as the baby oil, power tools and tissues are concerned ... Yeah, not going there
The Vit gearbox sounds pretty plausible for 6x6 but you'd have to be careful to unlock the front hubs on the road. If not you'd end up with horrible transmission wind up. I quite like the drive through diff idea but lining up the pinion on that second carrier must be a complete nightmare. The old Fiat Panda 4x4 used a similar setup to get drive for the back axle. The gearbox is basically a conventional transverse front wheel drive box with an added crown wheel on the diff driving a pinion and a dog clutch to select 4x4.
- Dirtbird
02 Oct 2021 10:49 #239072
by Dirtbird
Replied by Dirtbird on topic lightweight buggy
Les just a thought if you google 6x6 Land Rover Perentie you'll find some videos showing how Land Rover gets the drive to both axels. Just a thought.
and this guy gives a good idea of how you could set up the springs.
Time to create page: 0.198 seconds
