Giving the Jimny a birthday
06 Mar 2021 23:51 #233497 by Scimike
Replied by Scimike on topic Giving the Jimny a birthday
I painted mine with the bearing jacket removed as they had failed. I was just careful around the hole and just wiped any paint that got in with thinners, a quick sand of the face with fine wet n dry before I pushed in the new bearing.
I Would avoid any grease or anything that will stop the paint adhering. I degreased the bits first, treated with Machinemart rust acid (to act as etch), then put it on.
It drys rock hard and any trace on the paint tin lid will glue it on requiring destruction of the can to get it out. Oh and don't get it on your hands, it won't come off!
07 Mar 2021 20:40 #233520 by Mike G
Replied by Mike G on topic Giving the Jimny a birthday
Sunday 7th March,
Ok, so got a fair bit done today, not quite finished with the grinding yet tho.
  • Fabricated spacers for the steering arm in preparation for the body lift (20mm for 2" body lift)
  • Fitted spacers to steering arm
  • removed exhaust pipe plus back box and wire wheeled it up to the cat (bought stainless one when I first got the jimny)
  • fitted new fuel lines and numbered for connection at tank
  • ran in new rear brake line
  • reclaimed more p-clip mounting points from broken fasteners on front axle
  • completed grinding of front axle
For the steering arm, I found some old steel pipe laying around that was the perfect diameter, cut it and filed both spacers 20mm length.  Not bad for the Mk 1 eyeball.  I also found some smaller diameter brass pipe that thankfully fitted in the small recess where the previous nylon spacers went, so I used the brass as an insert and wrapped some tape to keep it a snug fit inside the steel pipe.  That way the spacers will be kept quite central.
For some reason, I decided to work on the exhaust rather than get on with the axle, think it was just because the axle was a bit too fiddly and didn't really feel like much progress was being made. However, once the exhaust was cleaned up, I got a second wind and used some grinding stones on the end of a dremel to catch as much as I could on the axle.  Turned out not too bad, it's never going to be perfect, but I can live with how it is.
Really just powered ahead with as much work as I could to keep things moving in the right direction and do things now before I forget.  Otherwise I'll be kicking myself once the body is back on.
2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
08 Mar 2021 19:56 #233553 by Roger Fairclough
I used Isopan to fill in the corrosion pits in the steering balls. Sand down when hard and then paint.
Roger
08 Mar 2021 22:12 #233554 by Mike G
I'll have a look at isopan, although I've already pushed the button on the por15 purchase. I did my old bike fuel tank with por15 and it seemed to be pretty hard stuff.
08 Mar 2021 22:45 - 08 Mar 2021 23:30 #233555 by Mike G
Monday 8th March,
Jobs done:
  • loosened off the drain plugs for the axles
  • cleaned up the rear brakes bleed screw channels
  • completed wire wheeling and dremel grinding on the second axle
  • cut off some knackered p-clip mounting points on the axles
  • fabricated some captive nut mounting points to replace the ones I cut off
  • welded the captive nut mounting points
  • painted all remaining suspension parts
Today I finished wire wheeling the other axle and moved onto the dremel with a grinding stone to catch all the hard to get places.  Whilst doing that, I noticed that the brake bleed screw was blocked up and needed cleaning out, so I did that to save a job later on.  Just used some small drill bits to clean out the channels and wire wheeled the outside, so it didn't look so grubby, probably should replace it, but I may upgrade to discs later on.   Then it was out with the torch again to get the drain plugs removed.  They probably need to be replaced as they were badly corroded.
I welded some nuts onto the back of the holes where the previous p-clip mounting points were.  For the other mouting points that I'd cut off, I found some metal sheet, I cut it to size, drilled, then welded a nut on the back and then welded them onto the axles.  Turned out not too bad.  Hopefully they don't snap off.
The weather has been a bit pants lately and all the suspension components I'd previously ground off and finished needed to be flashed over with the wire wheel again to remove the surface rust from the dampness.  I chucked the space heater on whlist doing this to get everything up to a decent temperature.  Once that was done, I decided it was time to mix up the paint, it was 1900 already, but managed to get it all painted just before 2100. Nearly a 12 hour shift tonight, but I just wanted to get the paint on to give it as long as possible to cure.  Tomorrow, I will have a look at the body work, so much to do there, slam panel, boot floor, sils and probably lots lots more.  Well if it wasn't for suffering, there would be no joy I suppose.
Last edit: 08 Mar 2021 23:30 by Mike G.
09 Mar 2021 09:57 #233561 by Roger Fairclough
As you have done, I wire brushed the surface corrosion and then neutralised the remaining with acid and then used the isopan. Then with a smooth surface to work on you apply your paint.
Roger
Time to create page: 0.246 seconds
