Sheet steel
- Basketcase
05 Aug 2018 19:57 #194847
by Basketcase
Sheet steel was created by Basketcase
I don’t know which section to ask this. Does anyone know where to get cheap sheet steel from just for patching the body mounts up? I need it asafp didn’t realise the mot was due on the jimny on 9th and I have a couple of patches to do before then and money is VERY tight so needs to be very very cheap or even free? Any help would be greatly appreciated!
05 Aug 2018 20:12 #194848
Replied by jackonlyjack on topic Sheet steel
You're miles away from me
Try local tip or scrap man. Local factories you just need an old filling cabinet or similar
- Basketcase
05 Aug 2018 22:23 #194850
by Basketcase
Replied by Basketcase on topic Sheet steel
Any ideas what thickness I should use to repair/rebuild the body mount on the chassis? May as well tackle that while I’ve got the welder going?
06 Aug 2018 06:36 #194854
Replied by yakuza on topic Sheet steel
Since i am not a skilled welder i like to use a proper welder and proper steel. Bought my MIG welder used for approx. 200£
The steel i buy from a local steel supplier, 1mm sheet steel is what i use. Not expensive. and a 1x2m sheet would keep you in buisness for a long while. Just remember to spray the sheet with oil to avoid it rusting before you get to use it.
If I get better at welding i might go down to 0.8 thickness but i guess i would burn more holes if i do. But they say 0.8mm is easier to form into the shape you need.
Tried using scrap steel found in dumpsters behind car repair shops, but they tend to be so thin it is a pain to weld when you are not so good at welding..
However for the body mounts you should see what thickness is there allready. when doing reinforced places on the body I try to use same thickness but use a larger reinforced piece.
I try not to lay sheets on top of each other as that is the best way to make rust.
The following user(s) said Thank You: Basketcase
06 Aug 2018 06:36 #194855
I would say 3mm minimum for the chassis
.Basketcase wrote: Any ideas what thickness I should use to repair/rebuild the body mount on the chassis? May as well tackle that while I’ve got the welder going?
06 Aug 2018 07:01 #194856
Another thing using scrap steel is that some of it has been produced for cold forming for mass production and not necessary the best welding specifications. In a dumpster you never know what you get..
Time to create page: 0.944 seconds
