Sheet steel
  • Basketcase
08 Aug 2018 07:07 #194912 by Basketcase
Replied by Basketcase on topic Sheet steel
I’m not using gas, I’ve got flux cored. Does that matter? Should I get a bottle of argon and use that as well as the flux cored wire?
08 Aug 2018 07:26 #194914 by yakuza
Replied by yakuza on topic Sheet steel
Should be ok but keep in mind the wind still so you get a steady flame.
The flux core will vaporize and create a flame cover to keep O2 out of the weld i think..
I have used mig welding only as i was told that would give me the best result when I had no experience.
When i have to weld outside I cranck up the gas flow to keep the cover.
I got this used old mig welder for cheaps but the gas is pricy especially when i forget to close the valve after using it :)
The following user(s) said Thank You: Basketcase
Time to create page: 0.301 seconds
