Discreet but capable
jackonlyjack wrote: Happy to hear that your 4L has returned matey
Sniper i think you need to let the wifey Know that a transfer box guard is an essential buy now to protect your new fixture
Jack
I have Jimnybits transfer guard going spare in the garage :whistle:
- Thank you received: 305
Jack
Not that it would have been politically correct, but that would have been useful to know before I bought one off James the other day......
To add doodahs to wotsit, the courier delivered it 20mins after I collected the car from the garage, after telling them I would be along with it for them to fit it whilst doing the transfer box.
Thanks anyway...... just my luck recently.
sniper
So with only 4000 miles on them, they are getting swapped for Eibach +30mm springs.
I have found buying Jimny springs to be a bit of a quest... Standard springs (as supplied by BigJimny) are fine for 95% of my use and probably perfect for 99% of Jimny users. I'm not an off roader but I do a bit of green laning, standard height springs with only a 15mm seat have gotten me through some pretty tough terrain.
I want to join in with the occasional RTV Trial and need just that little more from the suspension than I thought.
The quality of "lift springs" is questionable, many people report sagging, body roll, even failure.
I have looked at Aussie makes, Tough Dog and Kings, Zanfi from Italy...... All very well reputed but beyond my purse.....
Eibach have a great competition history and at around £220 for the set, they are the best compromise I can find.
I will fit the existing 15mm SuperPro seats too, so a total lift of 45mm. I will also fit castor correction bushes, it may be over castor'd but having seen Jackonlyjack running with 3" arms and a 2" lift. I don't think it will be a bad thing, his car drives very well.
My AVO shocks are plus 30mm, fitted on repositioners so they should be fine, I also have +30mm bump stops....
Might fit limiting straps just incase I get too enthusiastic when trying the trials....
sniper
- Thank you received: 706
Maybe think about extended brake hoses. Dave at llama 4x4 could make you some specific to your lift
also a anti roll bar disconnect device like the JB ones
or one to your own design (I have 2 i won't be using) free of charge Pal
Anti-roll bar disconnect is a good suggestion and one that had escaped me thanks jack....... I'll happily have a look at those you've got.
Just ordered the springs, castor bushes, panhard bushes, 25mm spring seat (drivers side front, for lean if needed). Hopefully here in a few days and then round to the lads at the garage. I'm hoping the fact that all the suspension was off last year will mean the job ain't too costly....
Our girt released some guilt money after spending a small fortune on the latest iPhone lol.
sniper
