Dave's Daily Driver Build Thread...
29 Apr 2016 20:26 #166007 by j999pre
Same. Phew!
Grey pick up Jimny
  • OllieNZ
30 Apr 2016 05:57 #166017 by OllieNZ
Replied by OllieNZ on topic Re:RE: Re:Dave's Daily Driver Build Thread...
S200KYS wrote:
OllieNZ wrote: Have fun fitting the rear corners ;) mine took a bit of playing to get right.
Have you got a photo of yours fitted OllieNZ ?
And how do they attach? Do I need to keep any fixings off the old bumper?
I'll stick a closer pic up later but there should be a couple in my Jimny thread. The only fixings I reused were a couple of the arch screws.
  • OllieNZ
30 Apr 2016 10:20 #166025 by OllieNZ
Replied by OllieNZ on topic Re:Dave's Daily Driver Build Thread...
[IMG
[IMG
[IMG
Pretty self explanatory really. The screw through the side goes straight into the body. The 2 in the arch go into the existing captive nuts. I did have to grind/bend/tweak the metal arch extension to suit. A standard slitting disc works well on the fiberglass if you need to trim the corners themselves.
  • S200KYS
30 Apr 2016 11:46 #166032 by S200KYS
Replied by S200KYS on topic Re:Dave's Daily Driver Build Thread...
Thanks Ollie! ;)
  • OllieNZ
30 Apr 2016 15:00 #166039 by OllieNZ
S200KYS wrote: Thanks Ollie! ;)
No worries :)
  • S200KYS
01 May 2016 18:16 #166089 by S200KYS
Replied by S200KYS on topic Re:RE: Re:Dave's Daily Driver Build Thread...
Bit more today!
Finished the bodylift off... First the steering shaft went back in, then...
Everything else was refitted...
And then drove the Jim out to clean the garage floor... lots of mud had fallen off!
Looking better! B)
Transfer Box out, ready for the Rockwatt Rocklobster to go in, and I'd sold the old mounts through the for sale section of this fine board ;)
Whipped the rear quarterlight windows out, drew round them and cut them out of the same tinted perspex that is going in the rear window of the fastback hardtop...
And then cut the rear window hole out!
Following the lines of the fastback as it narrows to the roofline...
Good rear visibility! B)
More in my own blog... ;)
Time to create page: 0.193 seconds
