Dave's Daily Driver Build Thread...
  • S200KYS
30 Jul 2016 09:32 - 05 Oct 2016 19:57 #170725 by S200KYS
Replied by S200KYS on topic Dave's Daily Driver Build Thread...
Breather parts arrived to combine with a kit from Martin's BugJimny store...
I didn't have any (8mm OD) tube to connect into the lobster box when I was fitting it... That will run into one of the side connectors on the manifold block pictured, then more 8mm tube will come out the other side and up to the top of the snorkel. The other three 6mm connectors will then link to the front and rear diff breathers, and into the gearbox breather using the straight connector also pictured...
Manual Free Wheel Hubs have arrived from Nicks_Jim via the for sale section on here, to be used with some spacer rings when I rebuild the front axle and steering eventually ([strike]next weekend[/strike] - didn't happen!!), with the following parts that have been amassed -
KingPin Bearings
Axle Oil Seals
Hub Knuckle Seals
Four Tie-Rod Ends
Rockwatt HD Steering Bars
JimnyBits Panhards
Bits4Vits Panhard Bushes
Previous owner said it had a wobble ;)
Last edit: 05 Oct 2016 19:57 by S200KYS.
  • S200KYS
30 Jul 2016 09:55 #170730 by S200KYS
Hmmm, no photo? You'll have to use your imagination then?
  • S200KYS
05 Oct 2016 19:55 - 04 Nov 2016 12:08 #173192 by S200KYS
Not updated this for ages, as not had the time to work on it for ages... August the ladies have their annual two weeks in the sun, and then we swapped symbol groups from Mace to Londis, so new tills, and redecorated the shop on the outside, new signage, etc...
[strike]But... things are finally returning to normal, and I hope to get back to working on the red one, as well as the keeping the blue one ready for our greenlaning adventures...[/strike] :blush:
Last edit: 04 Nov 2016 12:08 by S200KYS.
  • S200KYS
04 Nov 2016 12:09 #174234 by S200KYS
Another abandoned project! :blush:
Concentrating on 'laning and maintaining the blue S200KYS Jimny ;)
  • NineCherries
04 Nov 2016 20:57 #174244 by NineCherries
Replied by NineCherries on topic Re:Dave's Daily Driver Build Thread...
So what's the plans now for it? Splitting it/selling it on or mothballing it?
I think the monroe shocks will be on my upgrade list at some point. You put some good info on this thread. :)
  • S200KYS
05 Nov 2016 14:50 #174264 by S200KYS
Replied by S200KYS on topic Re:Dave's Daily Driver Build Thread...
GONE already...
The Jimny was collected on Wednesday by it's new owner...
The Rocklobster has gone, KAP Bumpers, lots of other bits...
Still got the wheels and tyres, and the lift kit you mentioned for sale -
www.bits4vits.co.uk/store/second-hand-parts/cat_104.html
Dave
Time to create page: 0.200 seconds
