Norwegian Jimny G16b
22 Dec 2014 21:40 #133070
by Mescort
bodø is north of the Arctic Circle
Yes there are lots of mountains here
G16B, Doug Thorley Header, Trail-Gear 6,5:1 Transfer, Front 28 Degree CV propShaft, Rockwatt crawler box kit, Zanfi 2" springs, Zanfi 10° + 10mm Front Radius arm, Caster Correction Bushes rear, Adjustable Panhard, Bilstein 5100 Shocks, Dotz dakar 15x7, goodyear duratrac 235x75x15, warn M6000
Replied by Mescort on topic Norwegian Jimny G16b
Rhinoman wrote:
Mescort wrote:
Rhinoman wrote: Looks good. Whereabouts in Norway are you? I drove through Norway many years ago and remember it as being quite mountainous, I should think that the G16B would really impress in an area like that.
I live in northern Norway Bodø
I see mountainsare you within the arctic circle?
- suzukisam
22 Dec 2014 22:18 #133075
by suzukisam
Replied by suzukisam on topic Norwegian Jimny G16b
Ive just started getting my baleno engine ready, im going to attemp to remove the pick up ring from the end of a 1.3 camshaft and put it onto the 1.6 camshaft, ive been told to use jimny inlet and exhaust manifold . How about all pulleys etc baleno or jimny also ive bought a cork sump gasket would you fit this or just use gasket sealant .
finally mine has got sump sensor / wiring do i need to block it off or just leave it there and cut wires thanks sam
22 Dec 2014 22:45 #133076
by Mescort
Yes use jimny inlet with baleno green injectors and jimny exhaust manifold
I used jimny pulleys... use silicone gasket, cork is for the g16a.
- gus2000
22 Dec 2014 23:55 #133080
by gus2000
Excellent work
Very good documentation
My sincere congratulations
Gustavo
Replied by gus2000 on topic Norwegian Jimny G16b
Gustavo
23 Dec 2014 06:46 - 25 Mar 2018 15:27 #133088
by Mescort
Warn M6000 winch, Warn Premium Winch Hook, Lowrange offroad fairlead, Rock Recovery™ Winch Line, ORA winch plate and Dragon wireless remote control
moved winch solenoid to the firewall
Last edit: 25 Mar 2018 15:27 by Mescort.
- Jimbospanner
- Premium Member
- Thank you received: 9
23 Dec 2014 07:01 #133089
by Jimbospanner
Replied by Jimbospanner on topic Norwegian Jimny G16b
Wow! Very smart.
Time to create page: 0.278 seconds
