08 Jan 2016 20:19 #160032 by Rhinoman
It looks like you have a crack in the axle casing:
The topic has been locked.
08 Jan 2016 21:21 #160037 by kirkynut
I think that's just marks in the dirt from where the diff guard mounts.
  • gaz3359
08 Jan 2016 22:42 #160044 by gaz3359
Replied by gaz3359 on topic Dave's "S200KYS" Jimny 'laner Build...
Good work dave always good to have a freshen up.sure the locktite will do the job.i use pu sealer on anything like that now works a treat and pretty cheap.
  • GraphicX
08 Jan 2016 22:55 #160045 by GraphicX
Replied by GraphicX on topic Dave's "S200KYS" Jimny 'laner Build...
iRTV silicone is great, never tried the 510 but reading the info on that link it looks like it's literally made for this.
not sure what peoples thoughts are with this but to get the diff out i've sometimes used a trolley jack just to help crack it, this is only when they literally will not come out. risk would be deforming the face it seals on but i've been lucky so far.
  • S200KYS
09 Jan 2016 13:37 #160070 by S200KYS
I've normally just used plumbing mastic when rebuilding diffs... and that's always been fine... in the past / with Vitaras
i'm not sure if it's the addition of the LSD in the front? Could it cause more twisting forces that could have unseated the diff in the axle casing?
i usually have to crack the seal with a specialist diff tool (a wood chisel!) to ease the two halves apart, but this time the diff was actually rocking against the axle it was that loose :blush:
Shouldn't be the diff getting hit, as it has a guard under it that is bolted to the driver's-side radius arm and clamped around the axle tube the other end, so I'm discounting that, hence the thought of the LSD?...
  • S200KYS
12 Jan 2016 12:55 #160214 by S200KYS
Just been to collect hubs back from local friendly garage...
£30 to remove old bearings and fit new... not too bad I thought?
And eldest daughter thankfully got her dates wrong! She's back to Oxford Uni' on Thursday not Wednesday, so I still get my day off tomorrow to start the rebuild B)
Time to create page: 0.819 seconds
