  • S200KYS
02 Jun 2015 05:10 #145280 by S200KYS
Replied by S200KYS on topic Dave's (Bits4Vits) Jimny 'laner Build...
Jezz wrote: Will the wheel studs still be long enough with a disc instead of the drum ?
Apparently?
Two of my 'laning mates have the kit fitted successfully...
Dave
The topic has been locked.
02 Jun 2015 06:47 #145282 by maverick
YES, long enough - the kit is designed to fit on Standard Rear Half-Shafts and Standard Discs. The only modification is that it requires Renault Calipers, which were on offer a the time (no brainer). Its a brilliantly designed kit and goes on in under 2hrs (1hr per side).... and too boot, I now have a brilliant hand-brake!
Jalapeño, IISY?
  • S200KYS
02 Jun 2015 07:00 #145284 by S200KYS
I'll measure the thickness of the drum and the 'replacement' disk out of interest later today...
Might take me a bit longer than that Brett ;) You know how I love working on brakes :blush: :dry:
Dave ;)
  • Tadpole
02 Jun 2015 07:38 #145285 by Tadpole
Replied by Tadpole on topic Dave's (Bits4Vits) Jimny 'laner Build...
Thanks for sharing your detailed work as always Dave ........ ;)
  • gaz3359
02 Jun 2015 07:49 #145286 by gaz3359
Replied by gaz3359 on topic Dave's (Bits4Vits) Jimny 'laner Build...
Looking good so far,something id like to do be interesting to hear your feed back.
  • S200KYS
02 Jun 2015 08:11 #145287 by S200KYS
Jezz / All for reference...
The drums are 7mm thick, the disks are 6mm thick, so no problem... B)
Hope that helps...
Dave ;)
Time to create page: 0.205 seconds
