- S200KYS
26 Mar 2015 17:03 #141391
by S200KYS
Bought... from the ORA (OffRoad Armoury), I believe they'll still make them to order?
Dave
Replied by S200KYS on topic Dave's (Bits4Vits) Jimny 'laner Build...
Whaley wrote: Have you made the sill protectors or are they bought ??
Dave
The topic has been locked.
- S200KYS
19 May 2015 08:45 - 19 May 2015 08:46 #144397
by S200KYS
Job for today... replace the rear prop as the UJ has gone in this one -
See the UJ wobble in the yoke without the diff flange moving...?
There's a noticeable "ting" when pulling off too...
Time to swap one of the spares in and later rebuild this one then...
Last edit: 19 May 2015 08:46 by S200KYS.
- S200KYS
19 May 2015 12:17 #144399
by S200KYS
AH, update... Prop off the Jimny and the UJ is well and truly knackered... go to fit one of the many other props I now have "in stock" and none of them fit?! Wrong length or wrong end*, so I've just come back from the local friendly garage around the corner, and they are going to replace the knackered UJ in the prop that was on the Jimny, and swap the end from one prop to another from my stock pile, and replace the UJ at the same time so that I also have a decent, correctly fitting spare...
UJs will come to them tomorrow, Wednesday, so should still be ready for greenlaning on Sunday... Good job I started early in the week...!
Oooh, and there's two sizes of UJs? So they've ordered two of each size to be sure, and will send the others back...
*Some are 8mm and some are 10mm, and have different PCDs too...?! :blink:
- Tadpole
19 May 2015 18:59 #144416
by Tadpole
Replied by Tadpole on topic Dave's (Bits4Vits) Jimny 'laner Build...
Thanks for the up-dates Dave, always interesting to read what you are up to .....
- gaz3359
19 May 2015 19:01 #144417
by gaz3359
Replied by gaz3359 on topic Dave's (Bits4Vits) Jimny 'laner Build...
Bit of play there dave good job you spotted it.when i fitted my rear prop i had to drill the diff flange so it would fit.
- S200KYS
19 May 2015 19:07 #144418
by S200KYS
It was even worse off the car Gaz
Thanks Tadpole
After reading Martins writeup again, and Gaz's comment, I think I might also clamp an 8mm prop onto the diff flange with mole-grips and drill a set of 8mm holes between each of the 10mm holes, so I've got a universal diff flange
Dave
Thanks Tadpole
Dave
Time to create page: 0.336 seconds
