- S200KYS
06 Nov 2018 07:38 #197379
by S200KYS
Errr, apart from having to cut a wheel nut off? :blink:
The topic has been locked.
06 Nov 2018 10:46 #197386
Replied by mlines on topic Dave's "S200KYS" Jimny 'laner Build...
Thanks for persevering with the posting, it was worth it in the end!
- S200KYS
06 Nov 2018 12:02 #197388
by S200KYS
And thank YOU for persevering with fixing the attachments issue
Another donation to your fine forum fund coming soon (as soon as I sell something!)
Dave
Dave
- Thank you received: 2004
06 Nov 2018 15:13 #197395
Simple as in not having to do that with an alloy wheel with a recessed nut!
- S200KYS
06 Nov 2018 15:59 #197396
by S200KYS
It was either that - cut the nut in half as much as possible and then attack it with a cold chisel - or weld it on from the back which is what I did on the other one that went, but that's only possible with a disk brake conversion, if the shaft's flange was in a drum brake I'd have had no option but to cut the nut off... God knows what you'd do with a recessed nut in an alloy wheel if the splines went and the nut and stud turned?!...
Needless to say I'll be welding the studs to the flange of the other TG HD shaft when it's next out...
07 Nov 2018 06:38 #197411
One of my mentors showed me a trick. Get an old socket of the appropriate size and a good twist drill that is a snug fit through the square of the socket an use it as a centric guide to start drilling the stud then once started use a slightly under size bit to go through the stud. Then the nut shouldn't be difficult to snap off with a long extension bar on the socket.
The following user(s) said Thank You: S200KYS, jackonlyjack
Time to create page: 0.221 seconds
