  • S200KYS
02 May 2018 21:53 #192346 by S200KYS
Replied by S200KYS on topic Re:Dave's "S200KYS" Jimny 'laner Build...
Thanks Stumpjumper / Daniel30 B)
Repairs didn't go as planned :( ...
LSD diff on the left, donor diff on the right...
Waterproof Grease and Copper Sealant for the kingpins came overnight Special Delivery, many thanks to Martin, some bags of replacement kingpin and ball seal bolts ready, thread lock and some chalk to mark the diffs to count the teeth...
Both 43 teeth, so a good donor diff with the right ratio...
Just need to swap the LSD carrier across into the donor diff then?...
Bugger! NOOooo... the bearing mount has sheared off :( :( :(
What to do then? :(
Spare rear axle in the garage :) Diff out, strip it and steal the 26 spline side gears out of it, strip and rebuild the donor diff with 26 spline side gears instead of the standard 22 then? And then my 26 spline Trail Gear HD shafts and CVs will go in... It will be am "open" diff, but it will get me to Sunday's annual punch hunt! :)
Carefully layout and label everything...
Hmmm, and then stare puzzled at a 2-pin diff?! I - as most of you know - come from the world of Vitaras, I've been driving them for the last 20 years before 'upgrading' ;) to a Jimny some four years ago, so the diff threw me slightly, so a quick call to my old mate Rockwatt for some advice, and...
I'm soon into the guts of the diff!
And the 26 spline side gears are in... rebuild the diff into the axle, shafts back in, hubs, kingpins, brakes...
Ran out of time today, back to work in the shop / post office from 6 til 9, so my lovely wife brought my tea round at just gone 8 so that I could finish at 9 o'clock and get back into the man cave for an hour and a half and finish the rebuild...
All ready for the punch hunt on Sunday! B)
Meanwhile, Rockwatt has offered to make me a new backing plate for the LSD by machining down a standard carrier! Awesome! So I should hopefully have my LSD back sometime in the future too...
:laugh:
The topic has been locked.
03 May 2018 04:21 #192347 by Lambert
Can't keep a good man down. Well done for perseverance!
  • Stumpjumper
03 May 2018 09:43 #192351 by Stumpjumper
Replied by Stumpjumper on topic Re:Dave's "S200KYS" Jimny 'laner Build...
Impressive doggedness, I would still be peering over a mug of tea & considering a number of excuses not to start the amount of work involved....
03 May 2018 10:31 #192353 by jackonlyjack
Good work chap can't be just giving first place to Brett at the punch :ohmy:
could you tell me the bolt sizes that you ordered for kingpins and swivel dust cover please
need to strip mine this weekend :(
thanks Jack
  • S200KYS
03 May 2018 18:00 #192366 by S200KYS
Thanks all ;)
Jack - bolts are the same suze as the originals ;)
Martin sells them in the BigJimny Store and I sell them on eBay as ZookBOB ;)
03 May 2018 21:25 #192375 by kirkynut
Diff pegging could be the answer to stop you stripping another crown wheel. Watch this:
Sorry it's about Land Rover diffs but the learning is the same.
Perhaps another service for Mr Wattam to provide, except I fear he is a little over stretched already!
Time to create page: 0.305 seconds
