23 Aug 2017 17:47 #183582
Replied by Riccy on topic Dave's "S200KYS" Jimny 'laner Build...
Lols! i would have thought with your use/abuse you give, it would have snapped the axle open by now?!
I agree the standard arm mounts are woefully thin, guess i havent got as far as breaking mine yet
Phil - did you do fit a circlip on the chat when it went into the CV? I missed it and stripped a TG HD shaft end right up with the airlocker!
The topic has been locked.
- Thank you received: 923
23 Aug 2017 23:01 #183601
LOL.... it was Phil who bought the Rob Storr front 26 spline HD shafts off me, and contacted me with a request for fitting advice when we were high above Portmeirion whilst greenlaning on Sunday -
So, I CB'ed the others to say we were pulling over to respond to a cry for help...
Hmmm, interesting thought as Brett "Maverick" is also abandoning poly bushes and going back to stock rubber bushes?....
Yes, more the axle to radius arm mounts I want to beef up rather than trussing the actual axle itself? But your thoughts on the TG HD shafts rings true if indeed the axle casing itself is bent? Perhaps the braced and trussed replacement axle will fix this then?....
Time will tell?!
Replied by X8GGY on topic Dave's "S200KYS" Jimny 'laner Build...
Gazguzzler wrote: Although I have superpro bushes all round, I do wonder if they are too stiff and causing too much wear on the axle plates. Perhaps genuine ones (although not as long lasting) would be kinder as they are more flexible?
Thoughts?
Phil
PS Got the HD shafts fitted - but had to use one of the used CV's, as the new one was a too tight on the shaft.
Riccy wrote: Lols! i would have thought with your use/abuse you give, it would have snapped the axle open by now?!
Time will tell?!
03 Sep 2017 21:28 - 03 Sep 2017 21:32 #183846
Blog of our Greenlane Driving Day in Snowdonia with GLASS yesterday -
greenlaning.blog/2017/09/03/glass-snowdonia-driving-day-020917/
I've developed a fault in that the T-Max Split Charge system has ceased to function, so the second winch / auxiliary battery wasn't getting charged on our last trip to the Lleyn Peninsula, so before I left on this trip I switched the manual battery link on with a battery switch I fitted four years ago, but that too doesn't seem to work anymore either?!
So I ended up with no CB or Winches, and had to splice a cable in to the engine battery to run the ARB compressor and switching electrics to get the rear air locker working for the day... so more remedial work to do!
Not a bad trip though, despite some bad route advice from the GLASS Rep' ?!?!?!
Last edit: 03 Sep 2017 21:32 by X8GGY.
- Thank you received: 1860
04 Sep 2017 04:03 #183848
Some lovely scenery and no mistake.
- Thank you received: 115
04 Sep 2017 08:22 #183853
by maverick
Jalapeño, IISY?
Replied by maverick on topic Dave's "S200KYS" Jimny 'laner Build...
A great day out with GLASS - and maybe we should attend as many meetings as we can to promote our Jimny group, and that GLASS isnt just for Land Rovers. Many Thanks to Dafed Taylor for organising this. It was a real shame that there must be hundreds of GLASS Members in the North West and there was only mabye a dozen turned up. Thanks to Tom in his RED 90 for leading in the morning, who claimed he had driven Hendry up and down (but he didnt want to come with us on our next trip there, on 17th September. We have three spaces up for grabs if anyone wants to 4x4 in the Tight and Scratchy lanes of North Wales, to include the now infmour Henryd (we prefer you to have a winch - probably not use it, but Henryd changes every trip we do).
Jalapeño, IISY?
11 Sep 2017 10:27 #183996
A bit of TLC yesterday...
On the last few trips I've had electrical problems
I'd replaced the ARB Compressor and the Odyssey PC1200 Winch and auxillary Battery, only to find that it was the T-Max Solenoid on the Split Charge system that had gone... So I sold the new ARB Compressor, taking a small loss on it, and then...
Ordered and replaced the T-Max Solenoid, the new ones ticks over nice and loud and proud
Refitted the Odyssey PC Battery
Replaced the three isolator switches, they were the cheap ones with the red keys, they are now still reasonable but fully sealed T-bar switches
(Top one is the manual battery link switch in the off position, the other two are the front and rear winch isolator switches - on in the photo)
I then turned my attention to the ground anchor -
Which, after having a stricken Land Rover Discovery hanging off it was well and truly twisted, and the welds had cracked
I'd originally asked a mate to take it into work and straighten it with some heat, but looking at it again I thought it was beyond repair... So I cut off the straight bits...
And welded new parts on where necessary... the arm is 30x80mm box with the 15mm original bracket welded into it... and then I welded 6x70mm plate over the top of the box so that it extended over the box underneath and welded it to both the middle of the spade's "hinge" and onto the 15mm handle bit...
Strong enough for a Jimny, but I won't be volunteering it's use for a Disco' again
All hammerited black and ready to go back behind my driver's seat...
I just want to add a piece of chain between the top two corners of the spade to strengthen it up when it's folded out...
Time to create page: 0.230 seconds
