My tray back
  • TomDK
25 Feb 2014 22:10 #106077 by TomDK
Replied by TomDK on topic My tray back
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configuration
idiotmobil wrote: what bender did you use for the cage my mates got a hydrolic one I could borrow and I can get cds tube at good prices through a friend but don't know about the bender
its one like this but from what ive found in the past they kink the pipe and if you need to do a bend that's to sharpe the pipe collapses or can you get mandrel for them types
Best thing is to use a proper bender, like this one.
Or similar. A centre press can be used for plumbing pipes, which are rather thick walled.
But for thin walled, CDS tube. You'll need something like the one in the link.
  • idiotmobil
25 Feb 2014 22:16 #106078 by idiotmobil
Replied by idiotmobil on topic My tray back
rusty spanner wrote: If you fill your pipe with kids play sand and pack it down bit of gaffer tap and both ends stop sand coming out should stop the kinking I use play sand as its dry works for me
ive hurd about that and u have just jogged my memory
  • idiotmobil
25 Feb 2014 22:18 #106080 by idiotmobil
ill keep my eye out for one of these im sure ive seen one in a friend workshop they have every thing as its a sheet metal business and they also build gt40s hope he has I know hes got a mandrell bender but ive asked before and that's just for there exhausts and its the wrong size mandrels etc
  • Vytrix
25 Feb 2014 22:22 #106084 by Vytrix
Replied by Vytrix on topic My tray back
i used a basic hydraulic bender. basically a bottle jack with fittings. just make sure you keep checking your bend cos its a bastard when you over bend it, not like you can straighten it out.
the pipe wont kink as long as you get good thick pipe, i think mines 3.2mm with a 42mm-OD.
making a trayback is basically the same as restoring your car. when its apart it gives you chance to get at the main rust areas and chassis.
its like new when its all cleaned down. well except for a couple new dinks :)
  • Mister Stu
25 Feb 2014 22:24 #106085 by Mister Stu
Replied by Mister Stu on topic My tray back
idiotmobil wrote:
winter wrote: well sort the rust befor it gets to bad! ;) and some thing which is front end heavy anyway your just making it even more front end heavy still dont get it .............
Mister Stu wrote: I done mine for 2 reasons..
1) If it aint there it cant rust
2) got board with a grinder in my hand :P
I mite be mistaken but im sure he bought it like it and found loads more rust and though sod it the backs coming off I like the way you can mound all the dirty offroading bits like anchor highjack etc on the rear and save getting the mud and wet in the cab
When i bought the jimjam the ass end was hanging out :laugh: If it was abit better i would have sorted it but it wasnt and iv always wanted to do a trayback :evil:
  • Vytrix
25 Feb 2014 22:25 #106086 by Vytrix
i think the pipe had to be heat treated or something, not much difference in price, if you tell them what your doing when you buy it they should sell you the right stuff.
Time to create page: 0.239 seconds
