Challenge trayback build
  • aniesigh
15 Nov 2011 10:59 #25810 by aniesigh
Replied by aniesigh on topic Re: Challenge trayback build
thanks Rob ;) , yeah don't worry that cross member isn't finished yet it will need to be dropped down between the chassis rails once box and props are in ive just left it up there unfinished while i wait for the engine and box so i can cycle the suspension and check for clearance, then it will be braced etc.
i'm always willing to listen to suggestions, thats half the reason for posting up the build thread as other people may think of things ive missed :whistle:
will be in touch soon about those rose ends i PM'd you on Devon about, will also need some bent tube for my shock hoops, will you supply those? i know you do shock hoop kits but i just want the bent tube really then i'll fab up the rest. oh and can you supply steel wheels with a decent offset?
cheers
  • aniesigh
18 Nov 2011 22:28 #26076 by aniesigh
  • TomDK
18 Nov 2011 23:31 #26078 by TomDK
Replied by TomDK on topic Re: Challenge trayback build
aniesigh wrote:
B)
arh sweet.. 1UZFE Lexus 4.0 V8 :-)
Awesome engine :-)
What's your plan for transmission?
  • aniesigh
20 Nov 2011 19:28 #26203 by aniesigh
sure is B)
its mated to a lj78 transfer box meaning i get both diff outputs being offest
  • supergaz
20 Nov 2011 19:33 #26204 by supergaz
Replied by supergaz on topic Re: Challenge trayback build
Looks like this is going to be a serious monster!
  • aniesigh
24 Nov 2011 18:53 #26516 by aniesigh
Update
Got the Rear panhard mounts started:
front top links are also started:
roughly assembled a hub and offered a wheel up to it to check for steering lock, seems OK so can carry on ;)
i should point out all the brackets are only tacked, all will be fully welded then braced up once the suspension has been fully cycled B)
more soon,
Adam
