Challenge trayback build
  • Mumbo Jimbo
05 Nov 2011 19:56 #25211 by Mumbo Jimbo
Replied by Mumbo Jimbo on topic Re: Challenge trayback build
Definitely looking forward to seeing this one progress
  • X-Eng Simon
06 Nov 2011 11:46 #25234 by X-Eng Simon
Replied by X-Eng Simon on topic Re: Challenge trayback build
I really like the SJ - as someone else said, if the Jimny looks half as good it will set a high benchmark for modded Jimnys.
It's great to see a few people doing the same kind of mods to Jimnys now that people have been doing to Land Rovers and 70 series Toyotas previously. I think it's a great base vehicle to work on and they are now cheap enough that extreme modded trucks are practical.
Si
  • aniesigh
06 Nov 2011 20:00 #25274 by aniesigh
Replied by aniesigh on topic Re: Challenge trayback build
Right so its back to the bare chassis, all mounts etc removed apart from a few crossmembers.
Seems the tin worm had well and truly got a hold of it!
Cleaned up:
Bit of cutting and drilling:
Then some welding:
Then I ran out of gas  had to finish it off with the arc!
Chassis should now be strong enough to hang my axles from  so started on lower link brackets:
Had abit of a fire cutting these out
Also some more bits for the parts section :
That’s all for now 
  • aniesigh
07 Nov 2011 21:11 #25331 by aniesigh
Right, got the axle lower link brackets tacked onto the chassis tonight, obviously once its all been cycled and checked for clearance etc they will be fully welded and boxed in.
It seems my jimny was a Friday afternoon build! What with all the rust and then after measuring up for the rear axle and being confused why it wasn’t measuring square I realised someone at Suzuki did a pretty poor job of welding on the mounts on the rear of the chassis!
  • X-Eng Simon
07 Nov 2011 22:10 #25333 by X-Eng Simon
Looks like you're doing a nice job there. It's a shame your Jimny is that rusty. Mine seems to be perfect apart from a little rot in the rear quarter panels and a bit of surface rust here & there.
This evening I glued together the mounting bracket for the LJ70 steering box and pan hard rod. Hopefully one evening this week I'll have time to glue it to the vehicle.
Si
  • bluejimny
07 Nov 2011 22:21 #25335 by bluejimny
Replied by bluejimny on topic Re: Challenge trayback build
bloody hell that was rusty, ive never seen one that bad
