Welcome to BigJimny
BigJimny is YOUR resource for everything to do with Suzuki Jimnys.
If you are new to the site then REGISTER through the LOGIN button
There is a friendly, active FORUM to discuss Jimny related subjects and a web SHOP for all your parts needs.
AS WITH ALL WEBSITES YOUR ATTENTION IS DRAWN TO THE DISCLAIMERS . As this website does not require a login to access content, the accessing of this website and associated resources is deemed acceptance of these DISCLAIMERS. Do NOT progress if you do not accept the DISCLAIMERS
Subcategories from this category:
SJ Rebuild
Lil Red - SJ restoration - Wings and Wheel Arches
Processed-WhatsApp-Image-2023-03-28-at-07.24.3211
As mentioned in the previous post for James' SJ, things are starting to go back together. Having bolted down the body it is time to add the doors and tailgate back on to align all the panels and weld them back in place.
After all the filling, sanding and priming, the first step is to ensure all the threads are cleaned out so that the bolts can be run in and out smoothly.
The doors and inner wing threads were cleaned
  8198 Hits
Tags:
Lil Red - SJ restoration - Body Mounts
Just a quick update.
Whilst seemlingly small this is an important milestone. Having painted the doors, tailgate and window frame parts separately. The time has come to join the body back to the chassis.
Early in the build the body was separated from the chassis to facilitate access to the corroded areas, although the previous pictures show the body apparently on the chassis, it was only loosely fitted and some of you may have noticed the apparent "lean" that that generated.
The time has arrived to weld the wings back onto the car and an important part of this is ensuring that the panels all line up, any panel gaps are even and all the shut lines line up.
Therefore the body needs bolting back onto the chassis so the panel alignment can be accurate.
  5539 Hits
Tags:
Lil Red - SJ restoration - First Paint
Its time for painting to start!
First there were a couple of small repairs left to door, Earlier you would have seen small perforations that had appeared in the bottom of the door.
These were removed and cleaned out and then filler welds were added to create an all metal finish that was then smoothed back.
  4327 Hits
Tags:
Lil Red - SJ restoration - Decals
276174397_7031301403610576_1689511998972359242_n
The aim behind Lil Red, James' SJ, was to restore it to factory condition. With the numbers of SJs declining rapidly and many "upgraded" into rough and ready off-roaders, it seems only right to preserve one in original specification without any modifications.
So, having passed its MOT in August, the plans have been firming up to get it restored.
  4862 Hits
Tags:
Lil Red - SJ restoration - The Stripdown!
Processed-IMGP603334
In our conversations with https://www.winchfield.net/  they requested that we perform the initial strip down prior to transferring the vehicle over to them. It took a few evenings but we eventually got there!
There were a couple of new areas with rust but overall the general state of the SJ was very encouraging!
See the pictures and video below!
  4440 Hits
Tags:
