Drive train - backlash(?)
- liamsjimny
18 Jul 2026 20:01 #264960
by liamsjimny
Drive train - backlash(?) was created by liamsjimny
Good evening,
Today I experienced a random, brief vibration whilst driving, seeming to come from the rear with a ‘graunching’ noise. It did it once and then on the way home, didn’t again. Looking under the Jimny once home, there was nothing obvious, though when first reversing, there was a knock. Shifting back to first the knock came again, though it is only once when moving between forward and reverse. Whilst under the car I noticed backlash in the rear prop. I wonder if this is normal, perhaps the source of the knocking and perhaps the vibration? Looking for some advice if possible. I’m concerned it is the start of something bad and would like to catch it before it worsens.
Thanks!
Thanks!
18 Jul 2026 22:11 #264962
Replied by yakuza on topic Drive train - backlash(?)
There will always be backlash and rotational play when you turn the drive shaft. It is the sum of all backlash in the gear mesh and must be there to ensure an optimal contact pattern between the gears.
My clunck noise have been getting bigger or more lately but then my car is abused and wear out faster.
The best way to check the diff is to take it out. But the easiest is to Jack up one rear wheel and, with the car in neutral 2wd, parking brake off, turn the wheel by hand first one way then the other, and feel for bumps or noises. Then the other wheel, same.
then both off the ground, in gear, engine off. When turning one wheel, the other one should go the opposite way smoothly.
- liamsjimny
19 Jul 2026 05:39 #264966
by liamsjimny
Replied by liamsjimny on topic Drive train - backlash(?)
Thank you very much for such a helpful reply! Will give this a go and check it out.
Much appreciated.
Much appreciated.
19 Jul 2026 10:15 #264967
by facade
Replied by facade on topic Drive train - backlash(?)
It is a 4 pin differential on the rear, and it always seems noisy and broken if you turn a wheel, you need to compare it against a known good one if you aren't used to it.
There is a CV joint at the front of the propshaft that can wear (badly if the rubber is broken) and cause vibration, and a spider joint at the rear that wears, test by grabbing the flange & propshaft and trying to twist them relative to each other.
Could the graunching be rust forming inside the brake drums? Have you taken it in water recently?
- The Coil Spring
- Senior Member
- Thank you received: 6
19 Jul 2026 19:47 #264968
by The Coil Spring
Replied by The Coil Spring on topic Drive train - backlash(?)
Could the 'knock' be caused by worn bushings (cracks in rubber) in the radius arms?
