Welcome to BigJimny
BigJimny is YOUR resource for everything to do with Suzuki Jimnys.
If you are new to the site then REGISTER through the LOGIN button
There is a friendly, active FORUM to discuss Jimny related subjects and a web SHOP for all your parts needs.
AS WITH ALL WEBSITES YOUR ATTENTION IS DRAWN TO THE DISCLAIMERS . As this website does not require a login to access content, the accessing of this website and associated resources is deemed acceptance of these DISCLAIMERS. Do NOT progress if you do not accept the DISCLAIMERS
The owner and site administrator of BigJimny
24/10/08 - Cutting the wheelarches
In order to fit larger wheels you have to cut the wheel arches to stop them rubbing. My Jimny was already modified so I have not had to cut the wheelarches myself. However a number of people have asked how it is done and what needs to be done. Therefore I have put photos of mine below to show what has been done. The pictures are clickable to make them larger.......
  12809 Hits
24/10/08 - Clutch Cable
Another common problem with Jimnys is a sticking/rough clutch cable. The clutch pedal becomes very heavy to press and there is a roughness you can feel under your foot. In fact this is such a common problem with off-road driven vehicles that I would check the clutch cable first rather than change the clutch.
The problem is that the cable seems to pull mud and dirt back into the cable sheath and gradually the cable liner wears through. So to changing the clutch cable.....
  10163 Hits
21/10/08 - Montys Jimny
Graeme AKA Monty has sent in some pictures of his modified Jimny.
Its current specification is:
2" suspension lift
Procomp 3000 shocks
2" body lift
15x8 alloys with 31x10.5x15 Insa Sahara MT's
12000lb cordless winch
rear diff locker
uprated transfer mounts
castor correction bushes
cb radio
spotlights
now resprayed in white no pics as yet
forthcoming mods
rocklobster transfer box
4"suspension lift
  10482 Hits
20/10/08 - Broxhead Common
We had a great day at Broxhead Common with TV4x4. Didn't get stuck once, although in all honesty we didn't try some of the difficult/wet sections as I was not willing to risk soaking the new clutch.
Only had a couple of problems, we found that the winch earth was dodgy so it needs to be re-made (we had to recover a couple of other vehicles) and I still have some sort of problem with the clutch or transmission. When you sharply release the clutch there is a loud BRRRT! noise, like a machine gun. The general feeling is that the clutch cable is sticking momentarily allowing the clutch to slip and as the clutch is still quite heavy to use I suspect that the cable inner may be worn (apparantly a very common Jimny fault).
There is an extensive album of pictures in the TV4x4 gallery HERE
The most exciting element was that there was a good complement of Suzuki Jimnys! This is the first event I have attended where there has been other Jimnys. I have put the pictures below.
  9159 Hits
20/10/08 - Ash's Jimny (updated)
Ash was also at the Berkshire 4x4 show (as his family organised it I guess he had to attend!) with his Jimny.
  12474 Hits
