Welcome to BigJimny
BigJimny is YOUR resource for everything to do with Suzuki Jimnys.
If you are new to the site then REGISTER through the LOGIN button
There is a friendly, active FORUM to discuss Jimny related subjects and a web SHOP for all your parts needs.
AS WITH ALL WEBSITES YOUR ATTENTION IS DRAWN TO THE DISCLAIMERS . As this website does not require a login to access content, the accessing of this website and associated resources is deemed acceptance of these DISCLAIMERS. Do NOT progress if you do not accept the DISCLAIMERS
The owner and site administrator of BigJimny
12/8/08 - Future Rust Problem?
One of the MOT failure points for my car was headlamp aim. Therefore I have pulled the headlamps out to clean and oil the adjusters and check the adjuster motors (UK Spec. models can have a headlamp leveling system).
The headlamps are pretty straight forward to remove, simply underdo all the wiring on the rear (unplug the lead from the main bulbs and twist out the indicator and sidelight bulbs,  prise off the headlamp adjuster power connector with a screwdriver) then undo the two screws (one top and one side) and then lever out the unit (this can require quite a push as there are two plastic locating pegs at the bottom rear that need to be dislocated).
With the headlamps removed I saw this........
  12114 Hits
10/08/08 - ASBOjimny update
As you can see Smiffy and Mac have been upgrading further.....
  8981 Hits
10/08/08 - Gaz's Jimny
Another one from Scotland (you will see ASBOjimny appearing in the pictures), this time a"work in progress" from Gaz.
  9292 Hits
01/8/08 - Update on MOT
Just an update (I am preparing a full article!)
Took the front hub off to find it full of water/grease....
  9563 Hits
28/07/08 - Stu's Jimny
Thanks to Stuart Bell for sending in these pictures of his fully modified Jimny.
  11392 Hits
